Author Topic: D44 axle breather location?  (Read 2229 times)
« on: July 03, 2007, 12:58:17 PM »
Just a quick question:  Where is the Cherokee D44 axle breather located on the housing?
Thanks
Re: D44 axle breather location?
« Reply #1 on: July 03, 2007, 05:00:47 PM »
Thanks
Seperate from the brake T.  I think around 6" in from where the brake T is.  You could always fill the stock hole and open up the hole that the T uses.  (This is how it is on the YJ and later Jeep)
« Reply #2 on: July 03, 2007, 05:06:01 PM »
On the TJ it is not on the housing but the axle tube on the driver side.  It is pretty easy to notice, the tubing from the port goes up towards the gas tank.
« Reply #3 on: July 03, 2007, 05:36:13 PM »
Thanks.  I was getting pinion seal leaks and thought it might be due to a plugged breather.  It looks like mine is set up with the breather hose attached to the brake T but I had read somewhere that the D44 had a separate breather hole.
Offline 95 Lowbuck
« Reply #4 on: July 04, 2007, 09:30:38 AM »
Jeffy is right,
I drilled and tapped the original T fitting hole on the D44
to accept the D35 breather fitting and plugged the stock one.
The D35 breather is a larger dia.
« Reply #5 on: July 04, 2007, 10:02:07 AM »
95 Lowbuck,
Could you tell me exactly where the original breather was located?
Thanks
Offline 95 Lowbuck
« Reply #6 on: July 04, 2007, 01:39:13 PM »
Like Jeffy said,
It is a little pressed in plastic fitting about the size for a vacume hose
that sticks out of the top of the axle tube about 8" away from
the brake T fitting towards the center.
Maybe yours got broken off somehow.
« Reply #7 on: July 04, 2007, 01:41:34 PM »
Thanks I'll have to look for that carefully.
« Reply #8 on: July 04, 2007, 01:43:08 PM »
Like Jeffy said,
They are easily damaged/crushed so it could be gone.
