Author Topic: 4.0L intake  (Read 2116 times)
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
4.0L intake
« on: July 24, 2007, 07:03:30 PM »
Is anyone running the 4.0L intake box and tube? If so, what's your opinion on its performance with the 2.5? I just picked one up from ebay and wanted to get some input.  ;)
Re: 4.0L intake
« Reply #1 on: July 24, 2007, 09:29:09 PM »
I'm runnin a Rubi 4.0L tube with a conical K&N, works real well to get the intake to the cooler side of the engine bay.
Offline dexetr30
  • Aloha Mr. Hand!
Re: 4.0L intake
« Reply #2 on: July 25, 2007, 06:10:45 AM »
Good to hear. Right now I'm running the craptastic set up that you see in the picture and I don't like it.
dirtyjeep95
Re: 4.0L intake
« Reply #3 on: July 25, 2007, 12:45:30 PM »
if you switch the location of the filter, won't it effect the brake booster set up?
Re: 4.0L intake
« Reply #4 on: July 25, 2007, 01:13:13 PM »
No, you can run the filter from anywhere.  Some even run it into the cab to keep water out, sounds like a turbo on the trail.
01amberfirewv
Re: 4.0L intake
« Reply #5 on: July 25, 2007, 03:20:47 PM »
I've wandered about doing this.  I am running a Rocket parts intake now but think the trails I run get a little too dust for an open element filter.  The 4.0 intake looks like it is much less restrictive
Liljeepz
Re: 4.0L intake
« Reply #6 on: July 25, 2007, 07:26:48 PM »
Wow! That 2.5L looks so much easier to work on and it looks nicer than my 2.4L.
