Author Topic: Suspension Sag  (Read 1779 times)
Offline 95jeeper
Suspension Sag
« on: September 02, 2007, 01:18:36 PM »
My rear suspension sags about 2" on my hardtop YJ. How can i go about and fix the problem. Is there a add a leef out there that will work with a lifted jeep, if so please let me know where i can get it.
95 rio grande 4" Skyjacker lift 1" shackel 33" tires, efan, 4.0TB, kn air filter, exhaust, and sound system. NV3550 conversion
Re: Suspension Sag
« Reply #1 on: September 02, 2007, 01:56:22 PM »
How much lift do you have?  A AAL will raise the spring rate which should help keep the rear from sagging as much.
My Jeep sits about a inch higher when I take the top off.  I can really tell the difference in ride with less weight back there though.  That's the trade off of stiffer leafs.
jeepheap
Re: Suspension Sag
« Reply #2 on: September 02, 2007, 03:14:38 PM »
i swithed out the aal on my jeep cuase it rode like a beat dog. i've riden hard tail harleys with more give then a yj with an aal,
Re: Suspension Sag
« Reply #3 on: September 02, 2007, 06:07:08 PM »
Yeah, you have to be careful when doing AAL's.  Many aftermarket AAL's are short, load leafs.  These are very stiff.  The good ones are full length.
Re: Suspension Sag
« Reply #4 on: September 04, 2007, 11:42:57 AM »
How old are your SkyCrapper springs?  They were known for sagging back in the day, I owned a soft set, don't know how the newer versions are.  They shouldn't be sagging that much with a hardtop.
