Author Topic: quick spare tire question  (Read 6129 times)
gomi
« on: October 20, 2007, 10:42:17 PM »
Hey guys, I was wondering if any has an answer for me. I just bought myself a full size 31 inch spare, can I use the old stock 9 slot 15x6 wheel? I just thought I would check before getting it mounted, it looks like it might work, but might the wheel looks very small. Thanks for any help.
Re: quick spare tire question
« Reply #1 on: October 20, 2007, 11:29:21 PM »
What are your other wheels?  A 31 will fit on there but it will be pinched a bit.  I like how they look with 31's though.
« Reply #2 on: October 21, 2007, 06:13:32 AM »
Assuming that it is 31 x 10.5", it'll be OK on a 6" rim.  The spare on my sons commanche is a 31x10.5 x 15 on a stock narrow cherokee rim.
gomi
« Reply #3 on: October 21, 2007, 09:17:30 AM »
I put the stock steel wheels that come from a sport or se, they have the 5 spokes if that makes any sense. The spare was an old school 9 slot though. I sanded it primed/painted a graphite. Came out quite nice but I was not sure if it will fit on the stock carrier. So should it fit with a 31x10.5? I really don't want to add extensions to the rubber stoppers.
« Reply #4 on: October 21, 2007, 10:58:51 AM »
I think they will fit on the stock carrier.  If anything you might have to cut down the bumpstops since the tires are fatter.  The other option would be to extend the tire carrier.
lanulos89
« Reply #5 on: October 21, 2007, 12:17:21 PM »
put the tire on the rim and mount the rim on the carrier backwards.  so that the front of the rim is facing the tailgate
gomi
« Reply #6 on: October 21, 2007, 12:35:28 PM »
??? interesting idea.
lanulos89
« Reply #7 on: October 21, 2007, 04:06:13 PM »
it works my buddy did it with a 32 once
« Reply #8 on: October 21, 2007, 04:29:52 PM »
Unless the wheel has a flat face on both sides it won't work.  I believe the 9-slots have a bevel.
gomi
« Reply #9 on: October 22, 2007, 04:31:46 PM »
Well, it fit....but the rear tail gate leans just so slightly becuase of the weight. You can't see it but I can tell when you close the gate, it catches a little. Any ideas, I tried to tighten it but had no effect. If I take the spare off it closes fine. :uhoh:
« Reply #10 on: October 22, 2007, 04:47:02 PM »
Mine leans a bit too.  I just left it and keep it closed.   :lol:  if you don't want to beat up the latch you can lift and close it.
gomi
« Reply #11 on: October 24, 2007, 07:30:13 AM »
If I leave it on do you suppose it will eventually continue to sag? Seems inevitable I guess, I use the tail gate alot. Anyone got any ideas?
« Reply #12 on: October 24, 2007, 07:36:47 AM »
This is on a TJ?  Suprising that a 31 would make it sag, rubicons come with a 31 from the factory.
For YJ's they sell tailgate reinforement kits - which get you up to the strength of a TJ tailgate.  Only other easy option is a bumper mounted tire carrier.
lanulos89
« Reply #13 on: October 24, 2007, 02:01:45 PM »
it sags downward correct , and its a tj right???..  just space out the lower rubber bumper more.  in theory it would push out the bottom more and straighten the whole assembly.
gomi
« Reply #14 on: October 24, 2007, 03:57:56 PM »
:confused: Not too sure what you mean. The gate itself is sagging ever so slightly, you can only tell when you open and close the gate. The latch catches a bit. Maybe I'll just leave it, unless it will get much worse.
