Author Topic: Aussie Locker, front or rear for daily driver???  (Read 9887 times)
  • Poseur Extraordinaire®
Re: Aussie Locker, front or rear for daily driver???
« Reply #30 on: October 22, 2007, 06:07:55 PM »
Mine's a daily driver as well...going with selectable front and rear...ARB.... :guns: :guns:
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
« Reply #31 on: October 22, 2007, 06:17:50 PM »
The ARB is my first choice but at $860.00 x 2, I'm not so sure. Then theres the cost of the compressor unit. I'm thinking Detroit Softlocker out back with an ARB in the front.
Rokcrwln
« Reply #32 on: October 22, 2007, 07:53:53 PM »
I run ARBs front and rear and it's great to run open on the road, but be locked when needed.
Plus when you're running easier trails with stock rigs you can run open and still have a fun.
For you 1% ers, I would spend my money on a good winch. Stuck is stuck, it doesn't matter if you're locked or not
Lockers just allow you to get stuck in deeper, tighter, more challenging spots, but if you have a winch you can always get yourself moving again.
Shawn_c
« Reply #33 on: October 22, 2007, 08:43:17 PM »
There is a lot of truth in that.  But my recomendation for the True Track was for multiple reasons.  The true tracks will make any rig, just about, a hero in the snow and ice.  It is several hundred cheaper then a detroit soft locker, and also strengthens a needed part in the lackluster Dana 35c.
cmgorman94
« Reply #34 on: October 24, 2007, 09:27:14 AM »
Thank you, you beat me to this.  To the OP, I tried looking at your profile, but couldn't really find anything on your Jeep.  I'm guessing it has the D35 rear?  I believe you also mentioned wanting to run 33's.  I'm sorry but that combination with any sort of locker is living on borrowed time. The 35 is just not strong enough for that. If I were you and had to drive in snow and just did a little bit of wheeling, I would consider an ARB or a winch.  Having a selectable locker would be the only real option IMO, but it's VERY expensive. The benefit would be having it turned off you would never know it's there, on you have a full locker. For the price you could get a pretty nice winch, and then you know you could get out.  Many people on this forum will tell you that a Warn will be the way to go. I agree with them.  They are truly the best.  I however, do not have that kind of money laying around, and have intimate experience with the ins and outs of the new Smittybilt winches.  My neighbor and I completely tore one down before putting it on his YJ, and I think it's a pretty nice unit.  After using it a few times, and going on the comments I've heard from you on what you want to spend, I think that would be a really good route for you to go.  It's something that will be a peace of mind for all stages of the Jeep buildup.  If you eventually decide you still want a locker, then look at axle upgrades such as a rear D44 or Rubicon axles, the rubicons come with selectable lockers, and in a TJ they just bolt right up.
Chad<----votes for a winch for 1% offroad use
« Reply #35 on: October 24, 2007, 12:11:53 PM »
Or a minimum, a Hi-Lift, rope or chain extension, tree saver, etc...  You'll probably want them even if you get a winch.  Also, if you go with a buddy a snatch strap will probably be the most useful thing.  It's a lot quicker for those times your stuck but not really bad.
BOOGIE444
« Reply #36 on: November 09, 2007, 12:56:27 PM »
Just a update, I ended up getting detroit truetrac's for both my dana 30 & dana 35.  I found a dealer on ebay that sells them for $350.00 plus $15.00 for shipping, I just couldnt pass it up.  Although I will probably need the extra traction because I am putting on crappy 33 x 12.5 wrangler at/s all terrian tires, as I am getting a practically even trade for my 1/2 used up 30 x 9.5 kumho MT's for 1/2 used wrangler at/s.  I guess I got lucky that the place installing my parts has the right sized used tires like that.
