Author Topic: Is a sye & drive shaft needed for 4" lift on a TJ ???  (Read 5968 times)
Offline lax22
Re: Is a sye & drive shaft needed for 4" lift on a TJ ???
« Reply #15 on: October 26, 2007, 07:36:10 AM »
4 inch will not look whimpy. What you also have to remember is that having a 4 banger you also have less weight up front. So when you add a lift that is designed to compensate for the extra weight of a six cylinder, you end up getting a little more lift out of the front end so you can get away with a little bit larger tire. I Bought my jeep with a 4 inch superlift already on it. Yes it dose have the spacers not the SYE, but if i could do it over i would get the 2.5 old man emu with a 1 BL. IMO Just the right ammount of lift so you can easily fit 33's and not look whimpy at all :thumb:
black99tj
« Reply #16 on: October 26, 2007, 08:52:15 AM »
Get a hack and tap Rubicon Express SYE with a CV RE driveshaft. Way cheaper, and with a 4 cylinder the output shaft doesn't need to be any stronget than it already is with up to 33 in tires.
BOOGIE444
« Reply #17 on: October 26, 2007, 01:01:28 PM »
The hack & tap RE sye look alot different than other kinds, it doesnt look like they have a new shaft with them either, do they work??
« Reply #18 on: October 26, 2007, 01:06:29 PM »
Does anyone have pictures of one installed?  Does it make the output any shorter or does it just eliminate the slip yoke?
« Reply #19 on: October 26, 2007, 01:08:53 PM »
You replace the output cone so the transfer case is shorter as well as eliminates the slip yoke.
« Reply #20 on: October 26, 2007, 01:16:04 PM »
Thanks.  I found this link too.
http://www.angelfire.com/nc3/84jeepxj/sye.html
I don't know, looks like the spline engagement gets reduced too much.
BOOGIE444
« Reply #21 on: October 26, 2007, 02:05:56 PM »
I just looked at the hack & tap install linky...
Thats not for me, I will just order a regular sye if I need one.
« Reply #22 on: October 26, 2007, 02:10:07 PM »
The reason for that length is because that's what the yoke rides on.  You meed a minimum of 2" or so for the yoke.  Since the new yoke won't be moving, it's fine.
Also, if you own a YJ, don't buy a hack & Tap.  YJ's don't have the rear seal in the housing so the Hack & Taps are usually $100 more then the TJ kits.  Strength wise, I've never heard of anyone having trouble with any of the SYE kits.
« Reply #23 on: October 27, 2007, 02:57:24 AM »
Unless you're like me and have dozens of TJ mainshafts and tailhousings sitting around to use with the H&T.
My H&T works just fine, but it's a little longer than the HD SYE kits.
« Reply #24 on: October 27, 2007, 01:23:15 PM »
Collecting them I see...  :lol:
The length of the SYE's used to range from 5.5"-4.5".  Then you have the super slim that give you another 2".
« Reply #25 on: October 27, 2007, 06:53:21 PM »
Leftovers from all the SYE installs, spare parts never hurt :whistle:
