Author Topic: tera flex long arm upgrade.  (Read 1304 times)
cmc1
« on: November 20, 2007, 06:17:40 PM »
  does anyone have any expieriance with these long arms or know anyone who does.I do most of my driving on the road and wondered if the longarms help that much to justify the 1000.00 price tag.I have a 4inch lift on a 1997 tj.No hills or rocks where i live.just wondering.chris
Re: tera flex long arm upgrade.
« Reply #1 on: November 21, 2007, 01:36:28 PM »
4" is the cut off for short arms.  The problem being the control arms become too short and the work angle is too big.  As you go taller, the axles are pulled inwards.  On a stock Jeep, the control arms are almost horizontal.  That's the way they were designed to work.  As you lift the Jeep higher and higher, the control arms start pointing down.  Ever hear of the TJ wheelie?  This is caused by the torque from the engine twisting twisting the frame which loads up one side of the suspension and if you input a little additional lift turn to help throw the weight to the outside, the driver front tire will pickup off the ground.  Sometimes you can get the rear driver side in the air instead.  Currie calls this 'Jacking'.  The is also why some people convert their rear suspension over to leaf springs.
Honestly though, unless you want to go with more lift 5+ and 35 and up, there isn't a need to go with long arms.  You don't rockcrawl and it doesn't sound like the trails are all rutted out so other then height, there doesn't seem to be much need for one.
cmc1
« Reply #2 on: November 21, 2007, 02:02:44 PM »
  Thanks for your answers.I do know what jacking is.when i bought the jeep it had a 4 inch pro comp lift on it.It had drop brackets on the track bars and a droped pitman arm.the first thing i did was remove the drop brackets(allways came loose)and put aftermarked track bars on it and a stock pitman arm back on.It helped 200percent.After that is when i noticed that turning to the left with a little throttle would lift the tire.Over all the ride is not bad now.pretty good considering i have cheap a-- general grabber at2 tires.Luckily there is a front end shop here that will cut your tires and balance them on the vehicle.The guy that worked on them said they were the worst out of round tires he had seen in a long time.He cut 3\8of an inch off of one to true it up.well thanks again for your replies.chris
