Author Topic: Anybody running 33x10.5's on the TJ  (Read 1883 times)
streetmaster
« on: November 22, 2007, 01:52:46 AM »
I seen a set of 33x10.5's on a TJ, that were on a some canyon's, and they didnt stick out at all which i thought was kinda cool looking. I believe the jeep only had a BB and i thought (I like it). So i figured id throw it on here and see if anybodys running 33x10.5 with a 4 popper to get some input, and if so what gears are you running?
lanulos89
Re: Anybody running 33x10.5's on the TJ
« Reply #1 on: November 22, 2007, 08:27:42 AM »
4.10's or 4.88's
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #2 on: November 22, 2007, 03:42:44 PM »
Yeah, I probably go with 4.88's on 33's. 4.10 aren't too bad but the 4.88's should give you enough to keep you happy at highway speeds.
GzrGlide
« Reply #3 on: November 22, 2007, 08:07:41 PM »
Been running 33x0.5 BFG MTs with 4.88 gears for almost 4 years. Love them and love the size. I'll be replacing them next fall with the new MT KM2s. I don't believe that 12.5 wide tires are necessary for most of us. Most people buy them because everyone else has them. BUt.......there's a much larger selection of 33 x 12.5 tires than the 10.5s.   :weee:
van
« Reply #4 on: November 29, 2007, 04:43:23 PM »
Put on 33x10.5 bfg ats on a couple weeks ago.  Running 4.10s.  Highway is fine except for large hills.  4th gear takes care of that.  2" BB in front, nothing in rear.  6" flares.  8" rims, 4" backspacing (if I remember correctly).  Everything tucks up nicely, no rubbing.
