Author Topic: Pretty much stock jeep tire suggestions??  (Read 4340 times)
ryanb
« on: November 26, 2007, 06:58:16 PM »
well i finally saed up enough money to go and get some real trail tires suggestions on sizes or brands? how will it effect my gas milage and acceleration? any sugggestions for improvements?
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
Re: Pretty much stock jeep tire suggestions??
« Reply #1 on: November 26, 2007, 07:08:13 PM »
I'd go with BFG A/T's. You can't get them in 225/15 but you could step to 235/15's. I'm using them and haven't had any problems with them.
« Reply #2 on: November 26, 2007, 08:14:46 PM »
I'd really consider 31x10.5R15 BFG KO AT's.  These are considered the shortest tire for 3 and up trails. (Rating system 1-5)  They will get you onto 80% of the trails out there and won't sap too much form the Jeep.  With any change in tire size you'll have to recalibrate your speedometer (easy).  You'll feel less torque with the larger tires since your effective gear ratio will change.  Offroad, you'll notice little to no difference.  Gas mileage shouldn't really change since you not lifting the Jeep and once the speedometer is recalibrate it will show the correct mileage. Uncorrected, you'll think you've lost 2-3MPG.
« Reply #3 on: November 26, 2007, 08:26:14 PM »
Where are you? What kind of trails do you/want to run?
gomi
« Reply #4 on: November 26, 2007, 08:53:40 PM »
+1 on the 31inch bfgs.
BOOGIE444
« Reply #5 on: November 27, 2007, 06:48:55 AM »
I would go with a 30" x 9.5" BFG mud terrian or kumho MT, wrangler MTR or really any MT radial.  In my humble opinion 30" tires take some of your 4 bangers performance away but the 31" tires make it a complete gas guzzling dog.
« Reply #6 on: November 27, 2007, 07:04:24 AM »
Mickey Thompson MTZ.  Great tire on and off the road at a good price  Grips like an MT but doesn't sound like a B52 going down the highway.
BFG AT are nice on the road, but completely useless for most offroad terrains.  Weak sidewalls, if you spend any time in sharp rock they will be toast  (I had a set for a couple years and took sidewalls out of 3 tires).
Goodyear MTR - great tire at a high price
The newest BFG MT looks promising
« Reply #7 on: November 27, 2007, 07:35:22 AM »
Since you are on a budget, there may be a cheap way to get a set of 31" tires and nice rims.  2006 and older rubicon rims and tires are a nice swap.  The tires are about 31" tall MTR's on 16" alloy rims.   I've got a set on my kids Comanche.  There always seem to be quite a few up for sale locally as the Rubicon guys go to bigger tires and different wheels.  You can get a set of 4 for $300 + around here.  Just make sure they are from a TJ rubicon and not the newer JK Rubicons (they have a different bolt pattern)
« Reply #8 on: November 27, 2007, 01:24:22 PM »
Rubicon MT/R's are HEAVY tires.  They are E class instead of C class.  The combo is nice but then you have a tire that weights as much as my 35's.   :stick:
« Reply #9 on: November 27, 2007, 01:29:10 PM »
Whoever you buy your tires from be sure to get road hazard.  I like American Tires, with their pro-rate, I can replace my tires for $20 each.
The Goodyear MT/R's are probably the best 50/50 tires out there that don't compromise much of anything.  Only problem is that they are expensive.
The new BFG's look great as well BUT they only come in limited sizes and are more expensive then the MT/R's.  :'(
« Reply #10 on: November 27, 2007, 03:24:30 PM »
50 lbs for a 245/75/16 E MTR   vs 50 lbs for a 245/75/16 BFG AT
If you want to compare a 31x10.5x15 size, then the BFG AT is 43 lbs and the MTR is 46 lbs
DodgeMudder
« Reply #11 on: November 27, 2007, 03:43:57 PM »
I say get a set of 31x11.50x15 LTB's nothing beats a swamper offroad, and after all it's a Jeep who cares about on road use.  lol
might4banger
« Reply #12 on: November 27, 2007, 03:47:13 PM »
30x9.5 Dunlop Mud Rovers... @ Sam's club. Cheap and light -
« Reply #13 on: November 27, 2007, 04:58:05 PM »
Cooper Discoverer STT.  They have worked very well for me off road and on.  Here is a link:
http://www.coopertire.com/us/en/ProductDetails.asp?ProdType=LtTruck&id=271&title=Light+Truck+Tires
The siping makes then better than most mud tires on wet pavement which is a real issue here where I live due to the strange asphalt used locally.
might4banger
« Reply #14 on: November 27, 2007, 07:54:05 PM »
Guess more detail is needed here...
I had ZERO traction issues with the mud rovers. They were soft enought that on the road they were tacky and stuck well - even in the rain. My 4 banger on 30's was able to hang with the 6's on the way to the trail.
36lbs a tire per tire rack. You can't go wrong with these.
