Author Topic: Question on ECU (aka PCM, computer) part #s  (Read 3285 times)
Offline VA_YJ
  • Now I need a CJ...
« on: January 19, 2008, 06:40:51 PM »
What's the correct OEM part number for an ECU for a '95 2.5 liter YJ with 5 speed manual?  ecudirect lists 56028829 as the correct unit, but others are telling me 56028828.  Does anyone know?  Gracias!
Re: Question on ECU (aka PCM, computer) part #s
« Reply #1 on: January 21, 2008, 08:37:09 AM »
I recently had to replace mine and have the number written down at home, let me see if I can find it tonight to post it in the morning.
Offline VA_YJ
« Reply #2 on: January 22, 2008, 09:11:21 AM »
Thanks for checking.  Just curios, what size tires are you running with those 4.56 gears?  VA_YJ
« Reply #3 on: January 22, 2008, 09:40:49 AM »
Sorry I forgot to check last night.  I'll put a paper in my shirt pocket this time so it won't get past me again.
About the tires, just 30x9.5 for now.  The YJ will get lifted probably around the end of this month and tires will be upgraded to 32x11.5 or 33x10.5 around summer time.
Offline VA_YJ
« Reply #4 on: January 22, 2008, 02:31:30 PM »
I'm running 31x10.5 with 4.11 gears - the ratio is too tall. I really need 4.56s to keep the engine in the powerband.  You would probably be better with the 32s unless you plan on regearing to 4.88.
I do like the idea of the 33x10.5 instead of 33x12.5.  Less weight for the 4 banger to turn and easier to steer, but with good ground clearance.
jimj
« Reply #5 on: January 22, 2008, 08:19:13 PM »
I purchased an engine form a 95 2.5L 5spd manual. The engine came with the ECU and its part # is 56028828 09/19/94. Hope that helps.
Offline VA_YJ
« Reply #6 on: January 22, 2008, 09:00:29 PM »
Thanks JimJ.  :wave:
I'd go with a light color on that desert jeep.  I have no AC and white paint.  VA_YJ
« Reply #7 on: January 23, 2008, 07:43:15 AM »
That's the same number I had ( 56028828) with a date of 11/22/95.  Good luck.
« Reply #8 on: January 23, 2008, 10:27:30 AM »
Mine is not a daily driver so I think it will work out OK, the worst that can happen is I will have to stop using 5th on the highway when driving to a trail.  Then again lower would also have been better for off-road.  My main reason for 4.56 instead of 4.88 was a long term plan to swap in an SM420, which has no overdrive.  Then 4th will work well on the highway and the granny low will take care of crawling off road.
Offline VA_YJ
« Reply #9 on: January 23, 2008, 03:08:05 PM »
neale_rs,
Thanks for your help.  I found the correct ECU on e-bay for about $100. :beers:
Good luck on your upgrades, I think I'd go with the 33s given your long term plan.  Have you looked at the inertia ring (weight) that mounts on your flywheel to help prevent stalling (and clutch wear) when crawling?  That might be a good mod for a mostly trail use rig.
VA_YJ
« Reply #10 on: January 23, 2008, 03:23:04 PM »
Great buy!  I'll look into the inertia ring option, or maybe an engine swap.
