Author Topic: OME HD lift gain?  (Read 1919 times)
mack90
OME HD lift gain?
« on: January 22, 2008, 02:05:55 AM »
Anyone running the OME HD lift on a 4 banger?  How much lift did you actually gain?  TIA.
Mack
wuze
Re: OME HD lift gain?
« Reply #1 on: January 22, 2008, 04:02:16 AM »
this is 2.5 ome with 285/75-16 :naughty:
and this is with 1" bl and belly up kit :clap:
i like the ome because its not so soft and rides on the
road perfect :thumb:
 :wave:
« Reply #2 on: January 22, 2008, 09:51:11 AM »
That is a nice low center of gravity setup.  I have a YJ but have often thought about building a TJ just like that (2.5 lift, belly up kit, and 33s).  I don't think a 2.5 lift is enough for a YJ because the front shackles will make the approach angle too low but a TJ can get away with it, especially with a high clearance gas tank skid plate to improve the departure angle a bit.
With the belly up kit, do you find you can keep up with 4 inch lifted YJs with 33 inch tires just fine?
wuze
« Reply #3 on: January 22, 2008, 10:23:01 AM »
 :naughty:
i have a high clerance gas skid plate :biggrin:
 :wave:
« Reply #4 on: January 22, 2008, 10:26:53 AM »
Wow, that's like my dream TJ!
So do you find you can keep up with 4 inch lifted, 33 inch tire YJs just fine?  That would be my goal for the build.
wuze
« Reply #5 on: January 22, 2008, 10:39:34 AM »
hmmm.....
i think ;)
because i have the better suspension :naughty:
 :wave:
« Reply #6 on: January 22, 2008, 10:52:42 AM »
Sounds like you haven't actually tried it but I think you could because the angles and ground clearance would be very similar.  The suspension would give you an added advantage as well.
