Author Topic: fuel filter  (Read 5981 times)
misfit
Re: fuel filter
« Reply #15 on: February 05, 2008, 06:46:56 PM »
its an 04 tj se, now i need to figure out why it dies every once in awhile.
Re: fuel filter
« Reply #16 on: February 05, 2008, 07:10:17 PM »
P0500 (M)
No Vehicle Speed Sensor Signal
A vehicle speed signal was not detected.
No signal from the speed sensor will cause the jeep engine to die when clutching or coming to a stop.  Get the speedo working again and all will be well.
What did you do wrong on the SYE that the speedo is not working?
Re: fuel filter
« Reply #17 on: February 05, 2008, 07:10:45 PM »
And forget everything you've been told about having a bad fuel filter.
misfit
Re: fuel filter
« Reply #18 on: February 05, 2008, 08:05:27 PM »
I didnt mark the position it was in when I took it off.  I heard that there is four different position it can go in so just turn it 90 degrees.  I hope that is all that is wrong with it.
RoKnAzn
Re: fuel filter
« Reply #19 on: February 05, 2008, 11:24:14 PM »
HAHA...seems like u found ur problemm...:P
Re: fuel filter
« Reply #20 on: February 06, 2008, 06:13:18 AM »
Easy fix.  Pull the speedo sensor out and find out what gear count the speedo gear is by reading the number stamped on it.
Next, find the number ranges embossed onto the outside of the black part that holds the speedo gear.  There will be a number range on 4 sides of the thing.
Insert the speedo gear into the tailshaft housing with the appropriate gear tooth range at the 6 o'clock position, straight down.  There should be a little nub on the tailshaft housing to line it up to but it's difficult to see.
misfit
Re: fuel filter
« Reply #21 on: February 06, 2008, 03:49:25 PM »
Thanks that is really handy to know. Thank you
Re: fuel filter
« Reply #22 on: February 06, 2008, 11:21:55 PM »
Dont feel too bad about this...  This is something most people assume others to know, so sometimes a newbe can put their new speedo gear in and insert the Speedo Gear sensonr in the wrong position (say, like the ORIGINAL position even thought the tooth gear required it to be rotated), and as a result, the speedo would fall into the TC tail shaft... Then you call Quadratec all angry that they sent you the wrong speedo, only to find out your own errors!
Dont ask how I know all the details of what happens when you do it wrong!
Felipe
forburg21
Re: fuel filter
« Reply #23 on: February 12, 2008, 07:44:39 AM »
the same thing happened to me.  my jeep just shut off when i was on the road.  i changed the oxygen sensor and did the reset thing and the check engine light still came on and still stalled out once in a while.  i put the fuel injection stuff in everytime i filled the tank because i was told that the fuel was too enriched or something.  its alot better but the check engine light still comes on.
misfit
Re: fuel filter
« Reply #24 on: March 31, 2008, 08:23:58 PM »
Well its been awhile but I tried this and it is in the right position and it still dont work.  I heard somewhere that I could have put in the speedometer drive gear in backwards when I put on the sye.  Has anybody heard of this?  I tried emailing the company that made it acouple of weeks ago and havent heard anything.  I also emailed the company that I got it from and still nothing.  Any help please.
Re: fuel filter
« Reply #25 on: March 31, 2008, 08:27:54 PM »
There is no backwards.
Here are some picts of when I changed out my speedo gear for the nth time.
http://4bangerjp.com/forums/index.php?topic=731.0
