Author Topic: SuperCharger Problem...Need Help Fix...:(  (Read 2750 times)
RoKnAzn
« on: February 03, 2008, 02:13:25 AM »
Well, I been having problems with my SC...I have dump almost 3/4 of Premium fuel these past 2 days...:( Plus, I'm Throwing 2 codes P0108 and P0172. Well, I not sure what should I get for Tuning it...Since Avenger Said I dont need one...but I think they lied...I was wondering how about the Optimizer II from Kenne Bell (Not sure they will do one for a 2.5L) or Split Second FCT-1 with ESC ($569 Plus getting it tuned). IDK what to do...:( Any Guidance?
Re: SuperCharger Problem...Need Help Fix...:(
« Reply #1 on: February 03, 2008, 06:14:13 AM »
Going by codes alone, sounds like you are running very lean.  Have you done any mods to get more fuel to the engine?  If you run a '91-'95 I would consider an adjustable fuel pressure regulator, upgraded injectors, and an adjustable MAP Sensor.  Have you check your air/fuel ratio?
RoKnAzn
« Reply #2 on: February 03, 2008, 12:39:40 PM »
From the codes it say Im running rich on Bank 1
« Reply #3 on: February 03, 2008, 12:58:52 PM »
The 2 codes together indicate a problem with the MAP Sensor
Did you do steps 36-40 on the instructions?
http://www.avengersuperchargers.com/images/2.5L_install_instructions.pdf
« Reply #4 on: February 03, 2008, 01:00:36 PM »
If you did those, then have you tested the MAP to see if it's working correctly - and put a vac guage on the intake port to see what it is reading?
RoKnAzn
« Reply #5 on: February 03, 2008, 01:12:57 PM »
Yes, I did those... but the Map Sensor cant read boost...So I put the Map Sensor in the stock location to not throw the P0108 code....:(
kenny kustom
« Reply #6 on: February 04, 2008, 11:05:46 AM »
FTC-1
internal 2 bar map.
RoKnAzn
« Reply #7 on: February 04, 2008, 11:08:59 AM »
FTC-1
internal 2 bar map.
Did you really need the Timing Retarded? If not couldnt you use the Split Second PSC?
kenny kustom
« Reply #8 on: February 07, 2008, 12:46:47 PM »
At full boost, you should.
RoKnAzn
« Reply #9 on: February 07, 2008, 01:51:42 PM »
ok, I guess I save for the FTC-19E Then....
Rob the plumber
« Reply #10 on: February 08, 2008, 09:07:42 AM »
Does this kit use a 2-bar map sensor?
RoKnAzn
« Reply #11 on: February 08, 2008, 11:18:07 AM »
I think its a 2.5 I believe....
