Author Topic: Clogged Cat  (Read 1859 times)
Offline bestos
Clogged Cat
« on: February 05, 2008, 11:23:59 AM »
Hey everyone.
Look out for the clogged cat, i could not get about 2200 RPMs and bad bad gas mileage.  I was hearing aLL kinds of rattling.  Paid 300 flat today to ahve the new cat installed and welded.  Jeep 4 banger runs much much better!
The shop that did the work said that there may be a leak in my exhaust manifold.  Said they could hear it after install.  Dunno.  My question is 2 fold.
1.  Could the clogged cat have caused that with the pressure and heat buildup over the last week?
2.  How much would it cost me to have a new stock manifold installed?  parts and labor.  my guess that if no studs break it is an 8 hour job because of the intake mani.
Re: Clogged Cat
« Reply #1 on: February 05, 2008, 03:25:20 PM »
Chances are the front and/or rear studs on the exhaust manifold are already broken, common problem on the 4banger.  If that's the problem, replacing the studs will seal the manifold back up.
Offline bestos
Re: Clogged Cat
« Reply #2 on: February 08, 2008, 10:24:58 AM »
10-4.  keep the stock mani?
how long is the job to replace the studs and nuts?
Offline bestos
Re: Clogged Cat
« Reply #3 on: February 11, 2008, 01:42:34 PM »
Bump, repeat
cmgorman94
Re: Clogged Cat
« Reply #4 on: February 11, 2008, 02:28:06 PM »
You'd have to look at it first.  If it's cracked, replace it.  If it's just leaking at the head due to a stud or bad gasket, keep it.  I put a header on my brothers 98 in a few hours.  That doesn't mean that a shop will only charge you a few hours, but you could always do it. It really doesn't take any crazy tools, and you would gain a little experience. It's really not that hard.
Chad
