Author Topic: T5 Bellhousing swap  (Read 1501 times)
floyd
T5 Bellhousing swap
« on: February 11, 2008, 08:53:17 PM »
Hi,Everyone. Anybody know if my 84 150-4 bellhousing that is currently mated to a T-5 will work with a AX-15?? Or better  yet if I find a 91 150-4 bellhousing will it work with my T-5. I need the crank sensor mounting hole to update to efi. Thanks.
Re: T5 Bellhousing swap
« Reply #1 on: February 11, 2008, 09:19:11 PM »
T-5, AX-5 and AX-15 aren't interchangeable.  You would need a Dodge Dakota bell housing to be able to use a AX-15 on your AMC 2.5L.
« Reply #2 on: February 12, 2008, 02:33:51 AM »
There are kits to locate a CPS on the harmonic balancer.
« Reply #3 on: February 12, 2008, 10:04:23 AM »
For the 2.5L?
