Author Topic: Lift Question  (Read 1761 times)
mack90
Lift Question
« on: February 19, 2008, 10:35:29 PM »
I have a 1998 SE with the 4 cylinder. The plan is to run 33 12.50's. I have an OME HD lift ready to put on. I will have a superwinch EPi winch on the front, Kilby gas tank skid in the rear. Also in the rear a body armor tire carrier. Will the lift alone be acceptable for 33" tires? Would you recommend spacers or body lift with this configuration. I know this has been talked about before, but I'm guessing the 4 cylinder with a lighter AX5 will net more lift with the OME than a 4.0L.
Any advice is appreciated.
  • Poseur ExtraordinaireŽ
Re: Lift Question
« Reply #1 on: February 20, 2008, 06:13:50 AM »
What size lift??  Personally, I think a 3" lift will be enough.
garydubf
Re: Lift Question
« Reply #2 on: February 20, 2008, 07:58:12 AM »
X2
Re: Lift Question
« Reply #3 on: February 20, 2008, 10:24:42 AM »
OME usually claims 2.5 but I have read that it may provide a bit more lift.  You could try the tires to see if they rub at full flex (it shouldn't be too bad) and then decide if you need a 1 inch body lift.
mack90
Re: Lift Question
« Reply #4 on: February 20, 2008, 12:45:31 PM »
Thanks.  I was hoping the OME 2.5" HD would provide a little more than that.  I wasn't sure with the extra weight though.
joe-joe
Re: Lift Question
« Reply #5 on: February 20, 2008, 03:27:16 PM »
You will need to add a one inch body lift regardless for the kilby gas tank skid plate to work. While you are at it you might as well add a one inch motor mount lift so you don't need to drop the t-case if you don't already have an SYE.
