Author Topic: water coming out under dash  (Read 1749 times)
nofearblackstar
« on: February 22, 2008, 05:32:19 PM »
not the radiator core . it comes out over both driver and pasanger side feat.
It was ranning for the past few days . I take the jeep out . it had a little drip over my clutch foot but nothin that bad . Started driving up a hill and it just pored out of both sides over the feat and by the speakers more on the passenger side then the driver. It was not ranning while i was driveing if that helps .
also its a 93 jeep wrangler . any help would be great . Thanks
Got Wood?
Re: water coming out under dash
« Reply #1 on: February 22, 2008, 06:04:17 PM »
Your heating and cooling system gets it's fresh air from the vent right behind the top of your hood, there is a drain that sticks down so that the air plennum doesn't fill up with water, if that drain is clogged it would fill up and when you go up a hill the water will roll back into the fresh air vent and onto your feet. You should be able to just remove the grate and clean out the drain tube.
« Reply #2 on: February 22, 2008, 08:55:14 PM »
My '95 does it, mostly leaks past the gasket between the windshield and the cowl.
nofearblackstar
« Reply #3 on: February 23, 2008, 01:24:07 AM »
sounds like the vent tube would be it. ill try taking the grate off and washing it out . im guessing it will be full of mud from the past few days of some intense mud sessions
ill let you know how it goes
« Reply #4 on: February 23, 2008, 02:51:38 PM »
Mine does it as well...  Do you have lights mounted on the windshield?  If so, the cable could cause the leak; I run my cables in from the sides so that at least water does not leak when driving, but it will still get in when it rains at night with wind (not that much, though).
YjMike
« Reply #5 on: February 23, 2008, 08:41:53 PM »
Soft top, rain the night before, late to work.... forgot to pour the water pools off the top.... bad day at work...
« Reply #6 on: February 23, 2008, 09:00:57 PM »
Mine did not do it when I had the soft top on, but it does now with the hard top (then again, I added the hard top, THEN the lights, THEN changed the windshield frame, so it can be any one of those factors!)
