Author Topic: trans swap  (Read 3049 times)
jrollings
trans swap
« on: April 10, 2008, 12:13:33 PM »
does anyone have a ax5 they are wanting to get rid of ? im gonna try to convert my 30rh to a 5 spd. i need everything that would go with it, slave cylinder, bellhousing, pedal assembly and all, thanks
jason
Rob the plumber
Re: trans swap
« Reply #1 on: April 10, 2008, 12:53:19 PM »
I thought about doing this myself too, but I understand the AX5 is made of glass, and not nearly as strong as the TF904.
jrollings
Re: trans swap
« Reply #2 on: April 10, 2008, 01:02:26 PM »
man that sucks, i was wanting an overdrive but not with a ton of work to do and all that other b/s
jason 00 tj
Re: trans swap
« Reply #3 on: April 10, 2008, 01:40:50 PM »
yeah the ax5 trans is weak .Good for a very lightly moded jeep and a driver with alight foot . I broke the reverse gear in half on mine and now i have a rebuilt and it's ready to blow when it goes i'm puttin a nv4500 in. bet i never break it and have a 5:61 first gear ! only draw back is it weighs 200lbs
Re: trans swap
« Reply #4 on: April 11, 2008, 10:53:12 PM »
AX5 isn't bad behind a 4banger, don't let anybody talk you out of it.  You wouldn't want it behind a 4.0L or v8, but it's all relative.
I've got quite a few power mods, beat on my heep pretty hard, and the AX5 is holding up just fine.  Most reported problems relate to synchronizers, which is the factory's fault for using and recommending the wrong fluid.
Clem
Re: trans swap
« Reply #5 on: April 12, 2008, 07:28:22 AM »
The other big issue is that DC used a poor quality snap ring behind the fifth gear cluster. It breaks causing you to lose fifth gear. I am doing a trans swap right now. It wouldn't be your flavor though...
You could look at an AX-15 out of a six cylinder. That is a straight forward swap. It would give you the 5th gear you want and the strength that you need. It is arguably strong enough to survive mild v-8 power.
wuze
Re: trans swap
« Reply #6 on: April 12, 2008, 08:44:44 AM »
i think about put a SM420 in my tj :naughty:
i sure i would love that 7.06:1 first gear :thumbsup:
i a easy swap and i dont need a overdrive, my tj is build for wheeling and not for the "autobahn" ;)
gerald :wave:
Jeep_Lust
Re: trans swap
« Reply #7 on: April 14, 2008, 08:45:43 PM »
You could look at an AX-15 out of a six cylinder. That is a straight forward swap. .
The bolt pattern on the bellhousing is different between the 4 cyl. & the 6 cyl.. Or can you swap bellhousings between an AX-5 & an AX-15?
Jeep_Lust
Re: trans swap
« Reply #8 on: April 14, 2008, 08:53:21 PM »
jason
Is the 30RH in good shape? I need an automatic, and I'm ultimately looking at a 700R4, but a stock swap would be a good temp fix. I could give you everything but the pedals, but you can get them on E-bay. (I could actually give you the pedals too, but I understand that they're a PITA to change.)
Clem
Re: trans swap
« Reply #9 on: April 14, 2008, 09:33:14 PM »
It uses a Dodge Dakota BH. There was a thread floating around here about it. There is a long thread over on Pirate.
jrollings
Re: trans swap
« Reply #10 on: April 15, 2008, 06:05:33 AM »
alright thanks for the help guys
95yjman
Re: trans swap
« Reply #11 on: April 15, 2008, 09:42:28 AM »
I'm looking into swaping trannys myself. If you can find a AX-15 I would do that, seems to be a much better tranny then the AX-5.  I've also looked into the NV3550 which came in some of the TJs...
