Author Topic: Vacuum reservoir?  (Read 1895 times)
Vacuum reservoir?
« on: April 16, 2008, 12:33:32 PM »
OK, I need your opinion; I have noticed that when driving against the wind, when I need to increase the throttle position to go up against a slight incline (or when the wid gives the 4 angry squirrels a hard time maintining speed), that the vacuum motor of the ventilation system has a very hard time keeping the outside air out...
My questions are:
1. Is this something I should be concerned about, or is it normal?
2. If it is normal (I think it is) for vacuum pressure to drop at full throttle with a havy load placed on the engine, I was thinking of using a small vacuum reservoir to help the HVAC system (particularly the vent part).  Would this be a good idea?
3. If (3) is a good idea, which vacuum reservoir would you recommend?  I have heard that some people have used fuel filters as vacuum reservoirs...  At some point I thought my brake booster was not getting enough vacuum (I thought that was the cause of my braking issues, but it was not) so I installed a vacuum reservoir for it, but I prefer not to connect any other vacuum accessories to my brakes; also, that reservoir is a little big for what I need, so I guess I'll just leave it where it is...
Anyway, I know I dont have any vacuum leaks because I changed most of the lines and check the vacuum level and it was fine; also, the Jeep is idling fine, and this only happens when the throttle is wide open (or close to it); if I let go of the throttle even some, the vent door starts working properly...  By the way, I wish Jeep had just used a cable actuator for many of the vacuum controled ones they did (like the axle disconnect and the doors of the vent system!).
Felipe
jrollings
Re: Vacuum reservoir?
« Reply #1 on: April 16, 2008, 02:44:59 PM »
i have this exact problem. does it slap shut or open everynow and then? is your lever sometimes hard to put from vent to heat or to off? mine is. i thought maybe i could put a stronger spring on the side of it that controls the opening and closing but i wasnt sure. if you end up solving this problem shoot it my way if you dont mind. ............hopefully im on the right track of what yours is doing as well.
« Reply #2 on: April 16, 2008, 03:07:57 PM »
Mine is not hard to move over (well, it is not "soft", but it is about what I would expect!), but it does come open and I can feel the air coming from the defroster vents when the engine has an open throttle and under load at speed...  I am thinking the vacuum reservoir would solve that, but I want to keep it as small as possible.  I think I'll give it a shot, and will keep you posted.
« Reply #3 on: April 16, 2008, 03:19:27 PM »
I am pretty sure it should have a vacuum check valve. once its in posiyion it traps vacuum unless there is a small leak in a hose. the control unit or the vacuum motor then it needs a constant vacuum supply, even with a vacuum reservoir it needs a check valve and a check for vacuum leaks in the heater control system
« Reply #4 on: April 16, 2008, 04:18:45 PM »
The vacuum reservoirs ussually (although not necesarilly) come with an integrated check valve...  I am planning to get one of these.  Actually, I would probably use 2 seperate ones; one for the cruise control (I installed an aftermarket one, and it is vacuum operated, so it probably is having a negative effect on the overall vacuum) and one for the HVAC.
Felipe
