Author Topic: Jeep throwing a code 65  (Read 1582 times)
cromwell
« on: May 14, 2008, 09:43:27 PM »
OK after looking in the FSM it states a code 65 is Power steering switch failure - Power steering high pressure seen at high speeds.  Now I get this all the time and need to know how to fix it.  Any Ideas???
Thanks
Tony
Re: Jeep throwing a code 65
« Reply #1 on: May 15, 2008, 06:08:22 AM »
Thanks
Tony
First make sure the switch isn't broken off like mine is ;)  If the code is true it means that the bypass valve in the pump isn't opening up.  The way to fix it is to replace the pump.
cromwell
« Reply #2 on: May 15, 2008, 10:03:29 AM »
May be a stupid question but where is the switch located?
« Reply #3 on: May 15, 2008, 10:48:04 AM »
If you look at the pressure line on the PS pump, there is a big black connector with a couple wires coming out of it.
