Author Topic: Jet Chip + Firepower ignition  (Read 1632 times)
RKBA
« on: May 22, 2008, 07:16:10 PM »
Is anyone running both a Jet chip and the hotter coil system at the same time?  I am interested if they complement each other or not.
Thanks
GreenBayjeeper
Re: Jet Chip + Firepower ignition
« Reply #1 on: May 24, 2008, 12:23:04 AM »
I am, and I like the combo.  The gains got ate up by new tires, but without them she'd be a real pooch.
Rob the plumber
« Reply #2 on: May 24, 2008, 06:28:25 AM »
I really don't think you need a hotter ignition system, especially with such short plug wires. I bet a dyno test would show little or no actual gains. The chip probably just adds a little ignition timing. Too bad we can't just advance the distributor and get more timing that way.
Before I put the turbo on, I added an electric fan, 4.0L throttle body with the intake ported, K&N, Ford 19# injectors, and a better exhaust system. It made a slight, but noticeable difference. By no means was it anything close to even peppy though. :)
« Reply #3 on: May 24, 2008, 06:57:58 AM »
What Rob said (minus the turbo ;)).  I have all that stuff plus the stage I chip (want a stage II now) and it all made a little difference and with the chip it did all kind of pop together and I have stock ignition.  I don't know where you are with gearing but I'd focus on that before a replaced a working ignition system.
RKBA
« Reply #4 on: May 24, 2008, 03:27:43 PM »
My TJ is already geared properly, I always do that concurrent with oversized tires.
I am running the Jet stage 2 with a 4.0 TB and a generic turbo muffler instead of the bashed up stocker.  The Jet does indeed advance the timing throughout the curve and makes a noticeable difference in idle quality and throttle response.  I believe that the advanced timing along with the large plug gap from the hot coil might be a good pair; just looking for someone's actual experience with that.
