Author Topic: Duralast plug wires and distributor  (Read 2227 times)
tommy_chunk
« on: May 24, 2008, 03:58:49 AM »
I see that Autozone carries all Duralast parts for cap and rotor, plug wires, and coil. I plan to use the Bosch Iridium Fusion plugs. Does anyone have this set up with the Duralast, maybe with different plug? I would be fine with it unless you have bad experiences.
My Jeep is at 66k miles. would it be better to change the coil too or can I wait?
Rob the plumber
Re: Duralast plug wires and distributor
« Reply #1 on: May 24, 2008, 06:23:52 AM »
You don't need to change the coil. They typically last for around 200K, and usually they fail all at once. They really don't slowly go bad.
« Reply #2 on: May 24, 2008, 06:53:18 AM »
Duralast is their house brand and  I have put their wires on several vehicles with no problem.  Its most likely the same thing a shop is going to put on for you (except the dealer).  They do have some thicker ones (high performance?) that are suppose to help.  I wouldn't change the wires unless you have a problem or want to improve the current ones.
tommy_chunk
« Reply #3 on: May 24, 2008, 06:42:41 PM »
That is what I was thinking, but I wondered if anyone has had trouble with them.  :nod:
Castr8r
« Reply #4 on: July 04, 2008, 06:38:02 PM »
I've tried several different plugs in Jeeps and find that the copper core Champions work best.  The Duralast tune up distributor cap, rotor, and plugs are good; no need to go fancy.  I have a hi-performance coil and really can't say that there's a lot of difference.  Stay with the stocker is my opinion.  Have fun!
« Reply #5 on: July 04, 2008, 10:06:40 PM »
Just keep in mind that the larger wires do nothing for you unless you run a hotter coil. Just keep with a standard size high quality set.
