Author Topic: 2.5L air intake or 4.0?  (Read 2727 times)
oletennessean
« on: June 04, 2008, 01:54:31 PM »
hey, i'm new to all this and i just got a 4.0L throttle body for my 97 2.5L tj and was curious as to which air intake i need to get for it now. any response is greatly appreciated, thanks,
dustin
Re: 2.5L air intake or 4.0?
« Reply #1 on: June 04, 2008, 01:56:54 PM »
What TB you use has no bearing on what intake you use.  The real issue is the location of the TB.  Because the 4.0L is longer the TB is moved forward more.  So you want a 2.5L kit.
JCAUDILL0034
« Reply #2 on: June 04, 2008, 01:59:15 PM »
i put a 4.0 throttle body on mine and used the stock intake but then bought a CAI and loss power and it was for a 4.0 also the tube covered the oil cap
oletennessean
« Reply #3 on: June 04, 2008, 02:13:11 PM »
thanks for the imput  :biggrin:
oletennessean
« Reply #4 on: June 04, 2008, 02:16:38 PM »
would i lose power with the 2.5l cai as well?
JCAUDILL0034
« Reply #5 on: June 04, 2008, 02:30:20 PM »
my buddy has one on his and it helped his out....so i guess each is different
« Reply #6 on: June 04, 2008, 03:13:56 PM »
Like I mentioned in his thread, it really depends on what you want.  There is no free lunch so to speak.  Most CAI's increase the volume but at the cost of a loss of velocity.  This changes the powerband a bit.
If you want more top-end horsepower then you do it at the expense of low-end torque.  You've got to play around with it and see if that's what you really want.  Same thing goes for the exhaust...
JCAUDILL0034
« Reply #7 on: June 04, 2008, 03:55:25 PM »
i forgot to mention i am running 33's and he has 31s so thats prolly where the difference came in at
