Author Topic: injectors on a 97 tj 2.5  (Read 1692 times)
new2jeeps97tj
« on: June 09, 2008, 08:05:37 PM »
well been over the forums for the last 2 weeks reading all that can be done on my hamster wheel to make it spin faster.  Never seen a defined answer on the fuel injectors for the 97 tj.  I understand that i need to use the 24lbs but do i need ford or can I use chevy or or any other manufactuer?   And is there any results from anyone doing 26lbs?        Also plan on keeping you all informed about a TBI spacer for a yj 2.5 that my buddy has that im working on for him .  gotta be a market out there for it
Re: injectors on a 97 tj 2.5
« Reply #1 on: June 10, 2008, 01:53:21 PM »
You need Bosch Injectors.  Easily found on FoMoCo's.
You could probably go with 26's if you've got more air entering the engine.
new2jeeps97tj
« Reply #2 on: June 11, 2008, 05:50:40 AM »
thanks jeffy, I plan on putting a set in this weekend
