Author Topic: Changing the Serpentine Belt on an 01 TJ  (Read 2117 times)
01amberfirewv
« on: June 26, 2008, 07:33:05 AM »
I need to change the Serpentine Belt on my TJ (at least 60,000 on the current one) and the idler pully doesnt seem to move.  Is it spring loaded or do I just losen the bolt and move the pulley?
  • Poseur ExtraordinaireŽ
Re: Changing the Serpentine Belt on an 01 TJ
« Reply #1 on: June 26, 2008, 09:39:21 PM »
You should be able to just loosen the bolt enough to pull the belt off..... :thumb:
« Reply #2 on: July 02, 2008, 07:12:53 AM »
Not sure when Jeep changed, (thinking 04 or so), but check behind and underneath the ps pump. The bracket holding the pump will have a bolt underneath it that is in a channel and a long adjustable bolt on the back. You loosen both and work the adjustable to pull/draw the pump to tighten/loosen the belt.
