Author Topic: Where to get bolts for the Roll Cage / Windshield frame?  (Read 2038 times)
« on: June 27, 2008, 12:54:14 PM »
Guys, I know someone here must have changed the 4 bolts that join the sportcage extension to the windshield frame; One of mine is completely busted and is currently out with nothing in its place, and although I have been to about 6 different hardware stores, I have been unable to find a countersunk bolt with the same thread pattern (I looked for both torx and hex, and still nothing!).  Any idea if ther eis anywhere I can get them online?
enginethatcould
Re: Where to get bolts for the Roll Cage / Windshield frame?
« Reply #1 on: June 27, 2008, 12:57:46 PM »
I had to go to a local shop that just delt with fastners. All they had was hex, which really didn't bother me. Did you check quadratec?
« Reply #2 on: June 27, 2008, 01:18:11 PM »
You will most likely be able to find them here: http://www.mcmaster.com/.  The previous owner replaced one of mine with a regular bolt and it just clears the door but works just fine.
« Reply #3 on: June 27, 2008, 01:41:00 PM »
Anyone happens to remember the bolt size?
« Reply #4 on: June 27, 2008, 02:03:18 PM »
I too just went down to the local Nut & bolt store and picked up some Allen head bolts.  They have a taper and sit flush like the torx.  Unlike the torx, they are made of hardened steel and not aluminum.
I forget the size offhand since I don't use them nor the support bars anymore.
« Reply #5 on: June 27, 2008, 03:00:43 PM »
I believe the ones you are looking for are The M8x20x1.25 hex. McMaster has them in stainless is part # 92125A284 for $10.41 per Pack of 25.
« Reply #6 on: June 27, 2008, 03:41:12 PM »
Thanks to all!  I will be placing the order for the 25 pack today...  If anyone needs some, of these, let me know (after all, I only need 4, so we can split the difference!)
