Author Topic: Electric Fan Installation  (Read 38591 times)
Re: Electric Fan Installation
« Reply #15 on: July 17, 2008, 04:06:58 PM »
That's the one I bought.  SHould work fine for a 4 cyl in the factory location
Actually not the one I bought.  Mine is the 18" variety
« Reply #16 on: July 17, 2008, 04:09:22 PM »
Bluemoon
« Reply #17 on: July 17, 2008, 04:34:34 PM »
ahh kool, thanks for the info. I found a 18inch fan on ther as well and its cheaper. Looks like (at least from the descriptions) that most of the electric fans would work in a jeep 4x4.
« Reply #20 on: January 24, 2009, 05:26:23 PM »
not to bring up an old post but figured we have enough threads about electric fans that i might as well add to one... anyways i went to the junk yard today with a friend and decided to get a electric fan from a Taurus... problem being i didn't do as much research as i should have / left the cheat sheet at home... so i ended up with a fan from a 94 Taurus with the 3.0l only to come home to see i wanted the 3.8l... the fan is a 2 speed and 15.5 inch fan. i am wondering if anyone knows if it will have enough flow.. couldn't fine any rating with a Google search (alot about the 1 for the 3.8l). but since from must of what i have read you guys are only using the low speed i would think that this one could work and at worst case have to use high...
long term i would like it to be able to cool a 4.3l v6. but would like to save a trip back to the yard to get the 3.8l fan.... or am i to lazy and i should just go back tomorrow?
http://www.autozone.com/selectedZip,55317/initialAction,partProductDetail/initialpartType,00997/initialR,4354883/initialvehicleId,1957501/shopping/selectZip.htm
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
« Reply #21 on: January 25, 2009, 10:15:38 AM »
I'm running a fan from a Lincoln MK VIII. I run it on the low setting only and it more than does it's job. I did manage to fry the temp. control module (most likely just the relay) over the last week or so. I may need to add a Freewheeling Diode to the circuit to protect it.
As for your problem. I don't think the 3.0l fan is the same part # and it may pull less cfm. I know the Lincoln fan I have sounds like a helicopter when it starts to wind up and it does pull a significant amount of air, even on low.
hyp7
« Reply #22 on: January 25, 2009, 10:23:37 AM »
I did the same thing found a 3.0 fan its is a single speed and it will work you can hear it inside the jeep going down the road. BUT it will pull hard on your motor and alternator. I would upgrade to a 136amp alt. It fits real good and works great.
« Reply #23 on: January 25, 2009, 10:54:33 AM »
my 3.0l fan is from a 94 and was onyl used 94-95 and has 2 speeds, has 3 wires 1 black 1 brown and 1 yellow, it will pull less air but it doesn't sound like id need anymore flow. i think ill just go with it and see how it goes.. but should probably get my temp gauge working again (hasn't worked once since i pulled the motor to fix the slave cylinder), and a better alternator of curse.
cletz97
« Reply #24 on: March 30, 2009, 12:21:52 PM »
What would the best wiring being for a tj that is more of a daily driver than an over roader?
as in cut offs for the fan and the temp
« Reply #25 on: March 30, 2009, 08:27:16 PM »
http://www.dccontrol.com/fancontrol.htm
I love my fk35, doesn't require relays and only pulls the minimum amount of amps required to keep the engine cool.
« Reply #26 on: March 30, 2009, 10:01:11 PM »
Same here... And the temp can be modified by jumpers of you so choose...
YJmechanic
« Reply #27 on: March 30, 2009, 11:59:08 PM »
i think i got mine from a 3.8 taurus for about 20$  and i still have it on low/  actually unless im sitting still for a while i dont even turn it on/  i drive to and from work with it off most of the time.
cletz97
« Reply #28 on: March 31, 2009, 06:14:54 AM »
How much did you guys pay for the fk35?
« Reply #29 on: March 31, 2009, 07:43:34 PM »
Around $130 or so, it's on the website.  Well worth it for me.
