Author Topic: lift kit help  (Read 1496 times)
willbacker45
lift kit help
« on: August 06, 2008, 09:57:26 PM »
so i am planning on doing a new lift on my jeep...zj front coils...2in coil spacers in the rear...and an inch +/- coil spacer up front inorder to level it...the zj coils are used so i will have to see how much they lift the jeep and then add the spacers as needed...i am guessing this will give me about 2in all the way around...i already have longer shocks and the 2in BB coil spacers installed, so what else will i need to put in the zj coils
i am then going to put 33x10.50 bfg mts on and then install a 1.25jks body lift and mml
how does this soud to you all? :dance: should be fun
Re: lift kit help
« Reply #1 on: August 06, 2008, 10:45:05 PM »
The ZJ coils are likely a stiffer spring rate, they'll really stiffen the ride of a 4banger.  I'd use the 2" coil spacers all the way around, plus a 1" BL, a common setup to clear 33" tires.
