Author Topic: sorry prolly another dumb ? but i need help  (Read 1233 times)
willbacker45
« on: August 09, 2008, 11:02:55 PM »
so i just installed a 2in BB on the jeep but the front is sagging about 3/4 of an inch and barely looks like i added anything to it, but the back seems up real high...so if i bought a 3/4 in spacer could i stack it on the 2in spacer to level the front?
dunklervogel
Re: sorry prolly another dumb ? but i need help
« Reply #1 on: August 10, 2008, 02:43:18 AM »
yes but if you installed a 2 inch puck on each spring shouldn't it raise each side 2 inches and not just the back?  you might want to check and make sure you installed it correctly or something.
« Reply #2 on: August 10, 2008, 03:00:09 AM »
A spare set of front coil isolators would work well to level out the front, they are stackable with the 2" spacers.
I had to add them when I put a 2" BB on my brother-in-laws 4banger TJ.  Worked great to level the ride.
willbacker45
« Reply #3 on: August 10, 2008, 07:43:04 AM »
so would i just use two isolators and then the spacers?
willbacker45
« Reply #4 on: August 10, 2008, 07:48:50 AM »
i just saw that mopar sells half in. spring isolators should i get those
