Author Topic: Performance distributors firepower ignition kit  (Read 17534 times)
JeeperTJ
Picture of the PD install on my TJ...
« Reply #30 on: December 31, 2006, 10:16:18 AM »
StvDiego
« Reply #31 on: January 02, 2007, 08:46:30 PM »
I installed the PD kit on mine about two months ago, and it does make a noticable difference. I think it's a bit pricey for what you get, but no real complaints. All-in-all tho, good quality stuff, I'm happy with it, and I got the red wires and a big decal to stick under the hood so it looks very cool!
But, if I was ever posessed by demons, became delusional, had a psychotic episode and in the midst of it decided to by a 4-banger again...   I would do it a bit differently.
I would probably do it more in a DIY fashion. Maybe a blaster coil and adapt it to the wiring, make the plug wires myself, the PD cap and rotor are just a better than stock set-up, so, with some effort and shopping around I could duplicate it pretty well and probably save some bucks.
Btw, I have a 2001 2.5 and I had to get the 31728-AH adapter for the coil, with that, the whole thing plugged right in.
RoKnAzn
« Reply #32 on: January 03, 2007, 08:06:45 AM »
Quote from: "Guardian7"
Now add a Jet chip and you'll be chirpin your tires!
BULLCHIT! :D
JeeperTJ
« Reply #33 on: January 03, 2007, 04:35:55 PM »
Quote
Me too on my 1999 2.5L, you can see the grey adapter plug with the green wire w/black stipe in the picture. $23 to keep you from having to cut and splice the wires...Ka Ching!
I thought the PD was a little pricy as well at 189 plus adatper for the 4 cyl, but I'm happy with it overall.  The Jet chip is also little more than I'm willing to spend at 309.95 for a Stage 1.  I think I'll pass or try to find one on ebay in the $150 or less range...If you look at the hp and torque curve on the jetchip website, it looks like it would make a difference.
chrisfranklin
Re: Performance distributors firepower ignition kit
« Reply #34 on: March 03, 2007, 05:19:55 PM »
I ordered a PD setup, received most of it yesterday and spent some time installing it.  Wires were ordered seperately and haven't shown yet, so I am using these 8.5mm Accel (?) performance wires I have
I'm using the Autolite Iridium XP plugs which are pregapped at .035.  Most of the platinum, silver, & iridium plug manufacturers seem to discourage buyers from regapping these plugs - probably because you might end up dinging up the electrodes while regapping and potentially screwing up the long plug life.  Nevertheless, I went ahead and regapped my iridium plugs to .065 as PD suggests and didn't look like I had any plug damage problems doing so.
Just using the brass terminal cap + new rotor and the PD screaming Demon coil + the .065 iridium plugs I already had made for a very nice performance improvement.  I admit, my old cap and rotor were "shot." But the Jeep's City/Highway drivability, now, is good enough to where I probably won't mess with any future performance improvments, so long as I am on 29 or 31 tires. If I go 33s, then I'll probably go 4.88s rather than mess with the engine any more.
Tuned (and geared) properly, the 4banger Jp ain't bad, despite what the haters say.
« Last Edit: March 04, 2007, 12:20:00 AM by chrisfranklin »
RoKnAzn
« Reply #35 on: March 16, 2007, 11:47:08 PM »
.065 Gap is what PD recommeds? That is almost double the gap.. umm..
lanulos89
« Reply #36 on: March 17, 2007, 02:01:09 AM »
hotter sprak double the gap make sence
« Reply #37 on: March 17, 2007, 11:59:53 AM »
Yes, PD recommends a gap of .065".  I'm running the prototype kit and it's been fine ever since I installed it.
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #38 on: March 17, 2007, 02:54:46 PM »
I'm running just the PD coil with a set of accel super stock wires. One of the best upgrades I've made so far. The PD wires were a bit to much $$ for me so I just used the accels since I had them sitting around as spares from a 351W build I did a while back. The accels worked just fine for me.
RoKnAzn
« Reply #39 on: March 17, 2007, 11:59:04 PM »
I wonder if it is worth it for me to do it.. ummm...
chrisfranklin
« Reply #40 on: September 11, 2007, 11:59:10 PM »
I've been running this PDI ignition setup with iridium plugs for about the last 6 months.  One of the things I probably should have payed closer attention to is the spacing of the LiveWires.
I had done the zip tie criss-cross setup in a couple of locations to keep the wires apart, but, as of last night, I noticed that the wires were still touching in a couple of spots and one was hitting the metal accessory mount for the AC.
Today I spent 5 minutes to seperate in 4 differnet locations with overlapped zip ties.  Now there's no contact, no touching metal etc. And the Jeep is driving like I was expecting after I bought the PDI setup: better low-end, better throttle response and none of the off-idle miss I had before.
PDI LiveWires are a decent-quality product.  I dunno how well they are insulated or whatever, but I get no radio interference.
However, the hotter coil  plus LiveWires definitely seems to require attention paid to careful separation of the Wires for optimum performance.  I've used "performance" type, thicker-gage wires -- but stock coil -- on previous vehicles and haven't noticed much difference whether the wires were contacting metal or each other or not.
« Reply #41 on: September 12, 2007, 12:49:05 PM »
You need to use Zip-ties?  You didn't buy the whole kit did you?  The kit should come with two billet aluminum seperators.  One for #1 & #2 and the other for #3 and #4.
chrisfranklin
« Reply #42 on: September 12, 2007, 02:34:08 PM »
They looked like they were priced fairly reasonably   $25 :eek::lol:
« Reply #43 on: September 12, 2007, 04:21:48 PM »
Maybe I should cash in and sell the extra one I have in my drawer then.  :ass:
