Author Topic: Brake Booster  (Read 4984 times)
Re: Brake Booster
« Reply #15 on: November 13, 2008, 03:04:48 PM »
This is what I'm going to be using when I get around to doing it.
1986 FORD E-350 ECONOLINE Engine: V8 5.8 Liter
And this is a direct bolt-on to the YJ's Booster?  Just take the old one out, put the new one in and bleed the brakes?
Re: Brake Booster
« Reply #16 on: November 13, 2008, 03:13:06 PM »
Direct?  No.  You'll need to ream/drill the mounts out.
Re: Brake Booster
« Reply #17 on: November 13, 2008, 03:21:29 PM »
Ah, OK.  Got it.  I'll try the Hawk brake pads, and if that does not do it, I'll go for the TJ booster and E350 master...  Man, this problem is starting to get expensive!
Re: Brake Booster
« Reply #18 on: November 13, 2008, 03:27:18 PM »
I had a chance to get a complete TJ setup for $30.  Doing the brake master and booster can be cheap.
