Author Topic: coil spring help  (Read 2014 times)
tasbm5
coil spring help
« on: October 18, 2008, 11:30:11 AM »
Hey Folks got a question hoping some one can answer quickly her goes i'm putting a BB in my 97 tj 4cyl and the coils being 11 years old and i asume saged out , would i benifit from putting 04 sahara coils in it if i even can where it's a 6cyl ? one other question would sahara coils be bigger or just more heavy duty because of the 6cyl engine? thanks in advance for any help terry..
Got Wood?
Re: coil spring help
« Reply #1 on: October 18, 2008, 01:29:11 PM »
I put 6 cyl. coils on my wife's 97 4 cyl., they gave it about .75" of lift.
Bill M.
« Reply #2 on: October 18, 2008, 06:13:44 PM »
Yes, the coils from the Sahara will give you a little lift. Its because the springs are stiffer to account for the  extra weight of the six cylinder. I've known guys who used it to even up the Jeep after a winch install. I am not too sure if the rear springs are different, but I am sure Jeffy does...
tasbm5
« Reply #3 on: October 18, 2008, 08:20:19 PM »
thanks for the info thats good news to me i'm not use to hearing what i want to hear .
        terry..
95yjman
« Reply #4 on: October 19, 2008, 09:47:00 PM »
You know I would maybe look for some springs that are off of a rubicon.  Don't those give you more lift?  TJ guys? :confused:
« Reply #5 on: October 19, 2008, 10:07:53 PM »
I would go for the other coils for the simple fact they're newer.
Or consider adding a second OEM coil isolator to the front budget boost to level the front out.
willbacker45
« Reply #6 on: October 22, 2008, 11:22:31 PM »
thats what i did  :biggrin: it works well
johnh
« Reply #7 on: November 22, 2008, 08:19:00 PM »
bump
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #8 on: November 25, 2008, 08:54:26 AM »
I added Rubicon springs and shocks on all 4 wheels. I got about 2"s (o.e. springs had sagged) of lift and the ride is definitely stiffer. When the Rubi springs we compared side by side with the 4 banger springs I noticed no difference in height. The Rubi springs are definitely made stiffer.
