Author Topic: Hood louvers  (Read 14809 times)
Re: Hood louvers
« Reply #15 on: October 23, 2008, 12:30:53 PM »
Some XJ owners put a small electic extractor fan right over the engine.  One local jeeper put one on his YJ after swapping in a V8.  It helped a lot with the cooling, very likely more than louvers.
XJ's especially the earlier ones have marginal cooling from the factory.  It shouldn't really be an issue with a YJ though.  Add some tube fenders and you shouldn't have any worries since there are no inner wheel wells.  :thumb:
Oilsmoke
Re: Hood louvers
« Reply #16 on: October 23, 2008, 08:13:42 PM »
Add a 4 cyclinder and you can cut the Heat  by a 1/3   8)
Re: Hood louvers
« Reply #17 on: October 27, 2008, 04:06:24 PM »
I went this route. I didn't have a overheating issue.  I was bored and wanted a easy project.
I picked up a 2 X 4 piece of the 1/8 inch holed steel for $7.00. I used some double sided tape to hold it on.
Re: Hood louvers
« Reply #18 on: October 27, 2008, 04:08:21 PM »
Buick Roadmaster or holl drill that hasn't been used since the taillights...  :lol:
Re: Hood louvers
« Reply #19 on: October 27, 2008, 04:09:46 PM »
I think that my favirite thing are your stickers!
Fool injected!  4 Squirrels Inside!   :roflol:
Re: Hood louvers
« Reply #20 on: October 27, 2008, 04:12:29 PM »
I get the Buick comment alot! When you stand back a few feet they look like stickers.
I used a jig saw to cut my tail lights :blbl:
Re: Hood louvers
« Reply #21 on: October 27, 2008, 06:00:20 PM »
3M foam tape?
Those MTR's are really chewed up.
BTW: what rocker guards are those? DIY?
Re: Hood louvers
« Reply #22 on: October 27, 2008, 06:24:49 PM »
It is 3M tape. I got it at Lowes. It's super sticky! I guess it does have a foam center. Maybe 1/16 thick 1 inch wide.
The MT/R's I got used. They were already siped. After running them a few years I grooved them. It's hard to see in that PIC. I sold the tires and wheels when I went to 37's. Which I bought used. I grooved them too. I don't have a PIC yet. I like the way they hook up!
Rockers are some Blem Genright. They are just down the street from me. I did have some homebrew ones on before that though.
Re: Hood louvers
« Reply #23 on: October 27, 2008, 07:20:40 PM »
mmm muddy water cooling system...
Re: Hood louvers
« Reply #24 on: October 27, 2008, 07:34:08 PM »
Not like the inner fenders are going to keep the engine that much cleaner.
Re: Hood louvers
« Reply #25 on: November 13, 2008, 08:26:25 AM »
Well, just thought I'd let everyone know I ended up getting the Pontiac louvers (like the ones in the article Moz posted).  I'll get some pictures after I install them...
islwayn
Re: Hood louvers
« Reply #26 on: January 08, 2009, 01:19:21 PM »
my 79CJ with the 401 HiPerf Turbo charged motor used to create a lot of heat..  I took it to a hot rodder friend that had a louver machine.. he punched louvers in the back edge of the hood to let the heat accumulated out.. I had the hood all repainted.. looks much better than those bolt in units..  classier for sure..  I put pans under them for the drain off so the water didn't dump on my engine..
YJmechanic
Re: Hood louvers
« Reply #27 on: January 09, 2009, 11:01:04 PM »
i have seen that article before and i like that someone did that good of research before a mod that most would just stick where ever looked the best,  on the other side i don't think with the e fan and a four cylinder you have much to gain in temp drop considered that combo creates a massive hole in the front anyway but i guess as far as heat escape it may help some, but i would just brake them anyway considering i walk across my hood when in deep mud and have to hook up or operate my winch
Re: Hood louvers
« Reply #28 on: January 10, 2009, 06:27:24 PM »
I would think it would help quite a bit, as when I open the hood, I can feel the heat coming out.  Also, when the fan kicks in, I can feel the hot air coming out from UNDER the Jeep...  I have yet to install them (same with the Safari Snorkel), though, so I have no idea if they will help or not.
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
Re: Hood louvers
« Reply #29 on: January 11, 2009, 09:00:46 AM »
Post pics when you get them installed. I've been thinking of doing this for some time. Maybe when the temps get a bit warmer (low single digits coming this week) I'll head over to the scrap yard and look for a set myself.
« Last Edit: January 11, 2009, 09:01:10 AM by dexetr30 »
