Author Topic: 2.5 swap  (Read 4331 times)
90jeepyj
2.5 swap
« on: November 25, 2005, 06:17:28 PM »
Hi
I just bought a 1990 Jeep Yj with a 2.5 tbi and I would like to put in a 91-95 2.5 mpi because I want to run a turbo (want to be different then the v6 and v8 swaps).
How hard is the swap and what wiring needs to be done?
The motor that in it right now is starting to get a bit of blow by in to the air box. I have change pcv valve and did a compresstion test and my #2 cyl is just a little lower then the other cylinder.
Thanks
shotgun
2.5 swap
« Reply #1 on: November 27, 2005, 08:21:08 PM »
I have been looking into doing this. Not a lot of info out there on this. I'd suggest buying a donor vehicle with a good wiring harness both in and outside the tub.
