Author Topic: Question about Hesco true roller timing chains  (Read 1401 times)
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« on: November 25, 2008, 08:20:33 AM »
According to the Hesco website the timing chains used on 2.5L, 4.0L & 4.2L Jeep engines are the same part. If I replace my o.e. timing chain set with the Hesco double roller timing set, will I have any clearance issues with the block or cover?
Here's the part in question.
http://www.hesco.us/shop.asp?action=details&inventoryID=43004&catId=7758
My o.e. timing set has almost 100K on it and it is stretched a bit. When I replace it I figure I may as well step up to something that may help me make a few more ponies.
« Last Edit: November 25, 2008, 08:21:17 AM by dexetr30 »
Matt vs YJ
Re: Question about Hesco true roller timing chains
« Reply #1 on: November 25, 2008, 05:47:57 PM »
There shouldn't be any clearance issues. You'll no longer need the tensioner that's inside the timing cover, so you'll just take that out and leave it out.
A double timing chain itself wont give you any more power, it's just stronger to handle the added strain of spinning a bigger cam/stiffer valve springs.
I bought the Hesco single roller chain and it was just a Cloyes #C-3085 chain. It was about 50% heavier looking than the stock chain. (However, I felt like an idiot for paying $120 for a part that I could have ordered for $40 on eBay)
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #2 on: November 26, 2008, 09:26:27 AM »
Thanks for the response. I'm going to shop around for a good price if that's the case.
