Author Topic: Hi-Jack mounting?  (Read 1193 times)
Offline smashcoast
Hi-Jack mounting?
« on: December 03, 2008, 08:35:14 PM »
I see 2 different types of mounting kits.
http://www.4wd.com/productdetails.aspx?partID=7047
http://www.4wd.com/productdetails.aspx?partID=13928
do they mount the same? If so i want to be able to lock it.
I'm going to mount it on the inside of my tire swing, so does anyone know which one is better?
Re: Hi-Jack mounting?
« Reply #1 on: December 03, 2008, 08:58:42 PM »
I've always liked them mounted between the rear roll bar... there is a thread about it somewhere on the forum...
« Reply #2 on: December 03, 2008, 10:22:52 PM »
This one says it will mount on flat surfaces 2.5 x 2.5 inches.
This one does not say. But it looks like you need a flat surface to mount it to.
Which one is better my depend on your swing out. Both are lockable.
« Reply #3 on: December 04, 2008, 05:42:53 AM »
The second one rattles a lot.    If you use your jeep as a daily driver I'd recommend putting the hi-lift inside so that it works when you need it.
