Author Topic: anyone running a M.O.R.E 1" body lift  (Read 5248 times)
01amberfirewv
« on: November 30, 2005, 08:21:03 PM »
I just picked up a used one.  Seems like quality stuff with all metal hardware.  How do you like yours?  How hard was the install?  Do you have any pics?
I plan on adding a MML after I get the BL installed.  What is the best one for a 2.5?
« Reply #1 on: November 30, 2005, 08:36:01 PM »
I was going to get a MORE set but decided against it when the JKS/Currie were on sale. :roll:
« Reply #2 on: November 30, 2005, 09:07:57 PM »
I have someone's which I don't recall whose. But here is a couple of suggestions:
- there are 2 body mounts above the rear axle, don't forget about those.
- while the body is off the frame, add the front grille spacer as there is room for your hands then.
shotgun
« Reply #3 on: December 01, 2005, 07:26:36 AM »
Most people around my neck of the woods have a poly 1" bodylift.  Since it's replacing the whole body bushing.
SMC4WD
« Reply #4 on: December 01, 2005, 09:11:52 AM »
I'm running a Daystar 1" bushing kit, with a 1" MML by the same company.  We had to do some custom modificatons to the 4.0L MML to make it work on a 2.5L.  I had wished that I used the MORE MML instead of Daystar only because it's rubber instead of the polyuthane bushings.
This didn't answer your question, it's just input.
MORE does a fantastic job, and you should be very satisfied.
