Author Topic: Spring and shock ?  (Read 1582 times)
Offline smashcoast
Spring and shock ?
« on: January 11, 2009, 12:29:37 PM »
Ok, I put on the springs from an 06 Rubi and new 5100 Bilsteins for the 3" lift.
So after we removed the old shocks which were RE from the BB and looking at the new bilsteins the RE shocks are much beefier and are the same length! So my ? is are the shocks they use for the BB the same as they use for there 3.5" lift as well? I was debating about just putting back the RE shocks and getting my money back for the Bilsteins. But I stayed with the Bilsteins and they are a much better ride.
Also once we removed the old springs from my 97 and compared them with the 06's the front springs were 1.25" longer while the rear was the same height and had the exact tags as the old springs.
So it looks like the Rubicon rear springs are the same as a regular TJ.
After the lift though maybe because the spings are newer I did gain about a 1/2 an inch in the rear.
While the front was 1 1/8 taller in the front, so it got a slight lift and leveled out the Jeep.
So my next thing will be adding an adjustable front track bar from JKS and Currie HD tie rod and drag links.
Then when I need new tires I will add 4" springs, long travel shocks and then start messing with the arm's.
Offline smashcoast
Re: Spring and shock ?
« Reply #1 on: January 11, 2009, 12:32:43 PM »
Also can someone with a 3.5" RE lift measure their shock lengths to see if they are the same as the BB one's?
Mr_Random
« Reply #2 on: January 11, 2009, 02:00:34 PM »
Wont moving the stock front springs to the rear net 3" anyways? I'm no TJ fanatic, so I don't know everything, but seem to remember reading that...
« Reply #3 on: January 11, 2009, 02:42:33 PM »
the front springs are considrably longer don't think that works to well.
The RE 3.5" lift will raise your Jeep about 4.5" those springs are tall, you will most likely have to do a sye and maybe a cv shaft to make it work, just keep that in mind. Currie steering is expensive but a pretty good choice
