Author Topic: Sucking from gas tank???  (Read 1890 times)
DEspence
« on: January 26, 2009, 09:43:25 AM »
I was woundering if anyone else gets a sucking from the gas tank when they take the cap off.  This might be a normal thing, I don't know? this is my first Jeep.  Any help would be app.
Re: Sucking from gas tank???
« Reply #1 on: January 26, 2009, 09:51:49 AM »
Sounds pretty normal. It mostly does it when your tank is real low.
« Reply #2 on: January 26, 2009, 10:06:15 AM »
Yup, mine does it as well...
DEspence
« Reply #3 on: January 26, 2009, 10:53:35 AM »
Cool thanks, I thought it might be a pluged vent.  and yes it dose it more when the tank is low.
« Reply #4 on: January 26, 2009, 11:49:18 AM »
Yes, it's normal since the gas tank should be a closed loop system.  When you have the pump removing gas air isn't able to fill it unless it comes through the Evap. canister.  Most of the time you're driving to a gas station then shut it off then remove the gas cap. The fuel pump causes a vacuum inside the tank.
rip_1986
« Reply #5 on: January 27, 2009, 09:32:16 AM »
so then its bad that mine dont do that?
« Reply #6 on: January 27, 2009, 11:40:12 AM »
What year is it?
