Author Topic: Throttle Body Whistle?  (Read 2146 times)
CrashTestRacer
« on: February 18, 2009, 09:49:23 AM »
I just installed the 4.0L tb on my tj and it works great but it has this really annoying whistle somewhere around 20-30% throttle. Has anyone else had this problem or know a way to fix it? I was considering porting the manifild i dont know if that would help?
TN00TJ
Re: Throttle Body Whistle?
« Reply #1 on: February 18, 2009, 11:04:11 AM »
Mine is totally stock (for now) and has done it mostly between idle and 1500 turns. I love it. Sounds like a turbo to me.
« Reply #2 on: February 18, 2009, 01:41:05 PM »
The only time I've noticed a whistle is when replacing the stock intake tube with an aftermarket tube and conical filter.  Simply changing from a 2.5 TB to a 4.0 TB shouldn't have caused a whistle by itself.
Crunch
« Reply #3 on: February 18, 2009, 02:15:34 PM »
Unless you have a leak somewhere maybe ;)
Offline VA_YJ
  • Now I need a CJ...
« Reply #4 on: February 18, 2009, 02:57:12 PM »
Maybe the IAC gasket is leaking?
GTChrisB
« Reply #5 on: February 20, 2009, 06:17:15 PM »
Get an intake for it and it will make a "woosh" sound too.  Kind of sounds like a turbo like TN00TJ said.
« Reply #6 on: February 20, 2009, 09:54:39 PM »
Mine does the same thing with the 62mm TB. It's not that loud, I notice it but it's not annoying. I also have a Rock-it City intake tube with K&N.
CrashTestRacer
« Reply #7 on: February 20, 2009, 11:08:20 PM »
yea i forgot to metion I am also running a cone filter which is probably why its so noticable. I'll see what happens when I port the manifold if all else fails I'll just throw the stock airbox back in.
« Reply #8 on: February 21, 2009, 12:18:57 PM »
It's the airtube and filter, as the stock setup is designed to dampen the intake noise.  Why is it so bothersome that you would go back to a stock intake?
