Author Topic: 89 wrangler issues  (Read 3745 times)
2.5Blues
89 wrangler issues
« on: February 25, 2009, 02:48:15 PM »
I purchased a 89 wrangler 2.5 tbi. It drove home fine. I started having problems with the next day. It was stalling out once it would warm up. At first it seemed like cat was shot. I dropped it down and check/hollowed it out. i replaced alot of vacum lines that were rotted. The fuel pump, sock and filter are new. I replaced the tbi as well. I installed a tps sensor as well. I noticed that the distributor wasnt hooked up to anything other than the plug wire that goes to the module on the firewall. O contacted the person i got it from he said the block was a 95 and didnt know alot about it cause he paid somone to do the swap. Where exactly does the plug for the pick go? i noticed the block on the firewall has 3 plugs and only 2 are being used. The reason i think this is my problem everytime u rev the motor the timeing goes way outta spec. any info would be great.
2.5Blues
Re: 89 wrangler issues
« Reply #1 on: February 25, 2009, 04:29:12 PM »
The plug is a 3 wire plug coming out of the distributor. the other distributor is only 2 wire. where does this go? how does it pull timing? help please!!
Castr8r
« Reply #2 on: February 25, 2009, 09:36:21 PM »
I think you have the distributor from the "95.  The '89 distributor has no low voltage wiring at all, and the ICU does not have anything plugged into the top receptacle.  Find a distributor from an '88 thru '90 and stick it in; should take care of the problem. ( I went out and looked at my '89 to make sure...)
2.5Blues
« Reply #3 on: February 25, 2009, 09:49:18 PM »
hmm i ordered one that is supose to be for a 89 and it has a plug as well. also had a vacum advance. got any pics?
« Reply #4 on: February 26, 2009, 08:25:14 AM »
weird that 2 people have this same problem of having the wrong distributor at the same time....  ??? :puzzled: as castr8r said there should be no plugs for the ecu on the distributor.
2.5Blues
« Reply #5 on: February 26, 2009, 01:13:04 PM »
That stinks. Anyone have a picture of what it should look like? I ordered one from jw jeep and its supose to be the one i need. I got one from a junk yard and it was missing the internals. just need somthing to referance since every place i talk to seems to be incapable of helping.
2.5Blues
« Reply #6 on: February 26, 2009, 01:18:35 PM »
heres what i have.
[attachment deleted by admin]
« Reply #7 on: February 26, 2009, 01:19:19 PM »
don't have a picture but there is a diagram of it in the [url/]parts catalog http://jeepgarage.free.fr/OWN/1988-1990parts-catalog.pdf[/url]. adn it gives the factory part number (being a parts catalog) should at least give you an idea of what it should be like.
« Last Edit: February 26, 2009, 01:20:21 PM by chardrc »
2.5Blues
« Reply #8 on: February 26, 2009, 04:01:25 PM »
Thanks i'll check it out
« Reply #9 on: February 26, 2009, 05:04:30 PM »
just a warning its a big file so it may take a few minutes to open up....
2.5Blues
« Reply #10 on: February 26, 2009, 06:33:37 PM »
yeah it was but a good reference thanks
