Author Topic: has anyone tried this?  (Read 4339 times)
JeepBoy2000
« on: March 04, 2009, 10:47:19 PM »
I was looking through jeepforum and came across an interesting idea on how to make a cowl intake. Has anyone else done this to their jeep??
http://www.jeepforum.com/forum/showthread.php?t=541004
Re: has anyone tried this?
« Reply #1 on: March 05, 2009, 08:38:19 AM »
that looks like a great mod... to bad i have a yj and don't think it has that much room behind the firewall... is it really that easy to get the cowl off a yj also?
Mr_Random
« Reply #2 on: March 05, 2009, 08:56:06 AM »
I wanna try it on my XJ, there's just not as much room, so I'll see how it works out...
JeepBoy2000
« Reply #3 on: March 05, 2009, 10:42:58 AM »
i think im gonna go ahead and do this mod to my jeep also along with a tbs. ill post up the results if i get around to it.
« Reply #4 on: March 05, 2009, 12:28:29 PM »
I like the idea except for one thing.  If you do water crossings that are deep enough to crest the hood, you could have problems, while under the hood it would be OK.  I kinda like the H1 intake and snorkel that some people have done.  Although this prevents you from lowering the windshield.  Not like that many TJ's do that though.
lanulos89
« Reply #5 on: March 05, 2009, 04:33:28 PM »
if you do water crossings that deep with a stock jeep the intake in the cowl will be the least of your problems
JeepBoy2000
« Reply #6 on: March 05, 2009, 04:59:47 PM »
the deepest water my jeep has seen was a couple inches deep and mud only 3/4 way up my 35in tire. 4ft deep water isnt something i come across, atleast not here in san antonio. i dont think im going to be driving through a lake anytime soon so i think ill be ok. :wave: i think the cowl intake should compliment the 4.0 throttle body pretty nicely and i will be running a pre filter.
« Reply #7 on: March 05, 2009, 07:48:24 PM »
Initial launching into water can cause a wave to crest the hood while not drowning the engine.
« Reply #8 on: March 05, 2009, 07:54:54 PM »
This possible on a YJ? Never tore down that far, so I don't know what's in there.
JeepBoy2000
« Reply #9 on: March 05, 2009, 08:13:02 PM »
i guess somebody tried it and it didnt work for the yj because of lack of space.. it says so about half way on the 7th page
http://www.jeepforum.com/forum/showthread.php?t=541004&page=7
« Reply #10 on: March 05, 2009, 08:36:52 PM »
The YJ does not have the pocket the TJ's do.  The pocket was made so they could move the wiper motor from behind the dash to under the hood so to speak.
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #11 on: March 07, 2009, 08:05:17 AM »
Yup, I plan on doing something similar. I'm looking to change things up a bit as far as the filter goes. I have to remove my cowl and get a good look at things and come up with a plan of action.
JeepBoy2000
« Reply #12 on: March 07, 2009, 09:02:28 AM »
i came across another idea were the guy uses the stock air box and routes it to the cowl. he plugged the existing hole from the airhorn thing and cut another. not sure if you would see the same results as an open filter but im sure this way provides better filtering.
http://www.jeepforum.com/forum/showthread.php?t=47537
« Reply #13 on: March 07, 2009, 03:52:07 PM »
By using the existing box, he's giving himself extra insurance that water isn't going to get into the intake.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #14 on: March 07, 2009, 07:53:10 PM »
Yeah, this is along the same lines I was thinking. I like the idea of using the o.e. air box.
