Author Topic: In need of picture and help?  (Read 2604 times)
1lonejeeper
« on: March 08, 2009, 08:30:50 PM »
I am in need of a picture of a 1990 yj 2.5 manual trans flywheel. I am doing some research about using megasquirt with the oem sensors.
1lonejeeper
Re: In need of picture and help?
« Reply #1 on: March 09, 2009, 06:19:54 PM »
I get the feeling no 1 has a picture or is willing to help...
Mr_Random
« Reply #2 on: March 09, 2009, 06:36:52 PM »
http://www.autozone.com/R,2456696/vehicleId,1666802/initialAction,partProductDetail/store,2761/partType,00906/shopping/partProductDetail.htm
Best bet.
It's correct... I have one from both TBI and MPI years, TBI (1990) looks as pictured.
1lonejeeper
« Reply #3 on: March 09, 2009, 09:38:12 PM »
I want to make shure it is right because the person that is going to write the code so I can use the oem crank trigger needs the info. He also needs to see the flywheel at tdc on cylinder 1 compaired to the sensor.
Mr_Random
« Reply #4 on: March 09, 2009, 11:51:25 PM »
Really, I can't help much more than that... I'll try to get outside and get pictures uploaded and everything before mine is shipped off, but I can't exactly tell you where TDC on #1 is gonna be.
I know there are 20 teeth per side, but I really can't say what that means for where TDC #1 will be either...
Wish I could help more... I understand the frustration with doing new things, personal research is sometimes the only thing you can fall back on in the end.
If I find anything more I'll let you know.
1lonejeeper
« Reply #5 on: March 10, 2009, 07:22:36 PM »
Thank you I think that is going to help with I am trying to do.
