Author Topic: CV Driveshaft for TJ  (Read 1989 times)
Offline VA_YJ
  • Now I need a CJ...
« on: April 09, 2009, 08:45:57 PM »
I've found a TJ front drive shaft (double cardan) for $50.  Can I have this cut down and balanced to use for a rear CV driveshaft?  It's from 97 4 banger with 55K miles.  I want to connect a dana 300 (flipped) to a ford 8.8 rear (longer than stock) with a 6 cylinder.  The tube is smaller diameter than the rear, so I'm wondering about strength.
If this won't work, can I at least salvage the double cardan and weld to a section of ford explorer rear driveshaft (V8 variety) and have that balanced?
Re: CV Driveshaft for TJ
« Reply #1 on: April 10, 2009, 03:10:39 AM »
It will work fine, as long as the d300 has a CV style rear yoke.  I often use shortened TJ & XJ front shafts in the rear.
Offline VA_YJ
« Reply #2 on: April 10, 2009, 08:00:09 AM »
Thanks.  I'll buy it this weekend.
