Author Topic: '00 Electronic distributor installation  (Read 3087 times)
TN00TJ
« on: April 14, 2009, 07:22:03 PM »
Let's suppose some doofus removed his distributor without having first set up #1 at tdc compression.  :brick:
Anybody know how to set that distributor up correctly for re-installation when the guy gets his motor back from the machine shop?
(Please don't flame the old goat.)
Mr_Random
Re: '00 Electronic distributor installation
« Reply #1 on: April 14, 2009, 08:29:10 PM »
Ha, good question... I've been fighting this for a week now, but I'll have two days off starting thursday, so I'll figure it out and get back to you if someone else doesn't help soon.
« Reply #2 on: April 14, 2009, 09:59:25 PM »
On a MPFI setup, either you're on or you're 180* off.  Anything else and the computer should compensate.  IIRC, the distributor can only go in one of two ways.
Mr_Random
« Reply #3 on: April 14, 2009, 10:38:54 PM »
Yeah, but if it isn't brand new, the position of the rotor has to be correct, as well as timing marks on the balancer (12 degrees BTDC if I recall), the oil pump drive channel or whatever also has to be correct for the distributor to seat fully anyways.
I've read it over in three different FSM's, but I'm just not confident enough that i can do it right without someone who already knows..
TrailsLessTaken
« Reply #4 on: April 15, 2009, 07:28:01 AM »
You can stick a long screw driver in and adjust the oil pump screw whatever direction it needs to be to set the distributor in.
For setting TDC if you have a compression tester, screw that on the first cyl. or have somebody hold their thumb over the spark plug hole if you have somebody to help you and crank the engine over until it starts to build compression.  You can also crank it over by hand with a 1/2" rachet, this is a lil easier with the spark plugs out.  Once it starts building, thats your compression stroke, take the tester off and stick a pencil or something in there and slowly keep turning it by hand with a rachet until the pencil reaches the highest point and starts to go back down.  Once you get that, you have your tdc set.  And then on the distributor itself you want the rotor pointing to the number 1 cylinder if i remember right.  and like Jeffy said if your one tooth off or something the computer will adjust for that.  Somebody else might want to verify me on setting the rotor though.
TN00TJ
« Reply #5 on: April 15, 2009, 08:37:10 AM »
Sounds like we're all pretty much on the same level.  I'm completely comfortable with arriving at #1 top-dead, compression once I reassemble the head to the block.
And...I do differential compression checks so that's pretty much a no-brainer.
8D17 in the '00 FSM gives you the process for both the oil pump and distributor but...their illustration shows an earlier distributor than mine.  There's where I was hoping to get some ideas.
I think that inserting the dist drive with the rotor installed should point the way and then, as a couple of you have mentioned, the computer should take it from there.
I'm still just kicking myself because I'm going with 62mm tb, spacer, header, intake, and cat-back so a SMART MAN would have done himself a favor and set everything up correctly BEFORE disassembly.  Aye-yi, yi.
Thanks guys.
TN00TJ
« Reply #6 on: April 15, 2009, 08:55:55 PM »
Let me wish you all the best.  I'll be curious to know how it works out for you.   :beers:
