Author Topic: front axle leaking  (Read 1953 times)
Bton
front axle leaking
« on: April 27, 2009, 02:06:44 PM »
Front axle is leaking.
This is what I got from NAPA.  Now my local dealer is not listing an outer axle seal.  I saw a lot of posts about this and couldn't resurrect any of them. So I reposted.
Is the seal partial metal and rubber?
Re: front axle leaking
« Reply #1 on: April 27, 2009, 03:52:28 PM »
Which side is leaking?
Bton
« Reply #2 on: April 28, 2009, 06:57:02 AM »
Driver side is now, but the pass side did awhile ago and stopped.
TrailsLessTaken
« Reply #3 on: April 28, 2009, 09:19:03 AM »
I'm looking at getting some of these Alloy axle tube seals for the outers
http://eastcoastgearsupply.com/i-128491-alloy-usa-axle-seals.html
« Reply #4 on: April 28, 2009, 09:39:18 AM »
THat's what I am running; I have had them for about a year, and there are no leaks, but the color fades rather fast, though...
TrailsLessTaken
« Reply #5 on: April 28, 2009, 11:03:54 AM »
Thats what im going to replace mine they look like they will do a lil better job then the old seal i had on, and they will be a nice natural brown color in a few weeks  :weee:
« Reply #6 on: April 28, 2009, 11:20:13 AM »
To th OP, there are several write ups out there. Yes the seal is rubber with an aluminum? outer ring.
At least the driver's side seal is the easy one.
http://www.stu-offroad.com/axle/d30seals/seal-1.htm
Bton
« Reply #7 on: April 28, 2009, 12:39:15 PM »
Thanks heaps, that site helped out big time. :dance:
and now I got the right ones after I found out that NAPA sold me hub seals. :asshat:  I should have known right then.
Bton
« Reply #8 on: April 29, 2009, 05:05:53 PM »
The bearing cap bolts, per the FSM for my 92 yj are the same as a 98 tj? 45 ft lbs?
« Reply #9 on: April 29, 2009, 06:36:17 PM »
I would think so.
