Author Topic: Front axle shaft u joint question  (Read 1662 times)
« on: May 01, 2009, 12:10:20 PM »
While going over my Jeep with a fine tooth come I noticed that one of the front axle shaft u joints turned about 1/8" inside of its yoke ear.
It still feels good. So the question is, can I just give it some paint marks and monitor it, after I put the retaining clip back in its original position.
The u joint it self is fine, does not feel stiff when you twist and flex it. We are going to spend in Moab and don't feel like doing a lot of wrenching on the trail.
Re: Front axle shaft u joint question
« Reply #1 on: May 01, 2009, 02:02:46 PM »
It's the ears on the yokes that have stretched. It will get worse and worse. When this happens they tend to pop the C clip out then the cap walks out then BOOM.
You have a couple of choices. 1. Replace the shafts. 2. Tack weld the caps to the yoke.
It's always a good idea to carry a set of spare shafts already assembled. Then if things turn brown it's a half hour of wrenching to replace a set of shafts.
« Reply #2 on: May 01, 2009, 03:56:39 PM »
I got spare shafts assembled as well as spare u joints. To not hassle next week, we are going to spend a week in Moab next week and run as many black diamond stuff as we can find. So to have fun and not worry I drove to Superior in Rancho Cucamonga and picked up2 new complete shafts. So that is the end of that worry.
I absolutely agree that they will open up more and will granate in the future. It's taken care of just did not feel like spending 600 clams, but oh well its a fun hobby lol
« Reply #3 on: May 01, 2009, 05:05:54 PM »
They are spendy but worth it. I had a set of Warn's in my D30. I ran all kinds hard trails with them. Never a problem.
Just make sure you use the full circle clips and mark the caps and yokes so you can keep an eye on things.
Did they come with Spicer joints?
« Reply #4 on: May 01, 2009, 05:57:31 PM »
Yup spicer 760's and full circle clips will put some paint marks on the caps.
I guess I cannot complain, I got about 7000 offroad miles out of the stock shafts and definitely abused them
