Author Topic: Mate an NSG-370 (6-spd) to 2.5L?  (Read 1587 times)
TN00TJ
« on: May 09, 2009, 11:44:45 PM »
Has anyone done, or even considered, mating an '05 or '06 6-spd (NSG-370) to the 2.5L? (Y2K)
It's a sweet little transmission and since I'm in the process of TB/cam/Banks/Flowmaster upgrade this is the perfect time to do it?
Thoughts?
(Jeffy, I'm not sure if this should have been posted in the Mess Hall rather than here.)
« Last Edit: May 10, 2009, 12:10:51 AM by TN00TJ »
Re: Mate an NSG-370 (6-spd) to 2.5L?
« Reply #1 on: May 10, 2009, 11:07:07 AM »
The problem I see is the 2.4L as well as the 4.0L use a different bellhousing bolt pattern then the 2.5L.  I doubt anyone makes an adapter so it would be a custom job.
TN00TJ
« Reply #2 on: May 10, 2009, 11:56:48 AM »
I assumed there would be a need for an adapter.
I'm going to call Advance in the morning but in the meantime, I thought I'd check with the Forum members.
DodgeMudder
« Reply #3 on: May 11, 2009, 04:24:26 PM »
I checked into this before I swapped the nv3550 into my YJ, everything I came up w/ is w/o doing allot of custom work it just isn't going to happen.
