Author Topic: freeze plug  (Read 1238 times)
95yjman
freeze plug
« on: June 11, 2009, 08:05:28 PM »
How do you go about replacing a freeze plug? The one leaking seems really easy to get too just don't really know the ins and outs of how to go about this.
Offline VA_YJ
  • Now I need a CJ...
Re: freeze plug
« Reply #1 on: June 11, 2009, 08:46:46 PM »
To change a press-in freeze plug:
Drain coolant, including engine block drain plug (left rear side of block) - if coolant is clean, you can reuse
Use a hammer and chisel or sharp punch to dislodge and remove leaking plug
Clean out the hole (look for any trash or imperfections that could be causing a leak)
Lightly coat the outer edge of the new freeze plug with RTV (optional)
Use a socket or other round object that is slightly smaller than ID of the freeze plug to drive it straight into the hole
Stop driving when the outer lip of the freeze plug is past the edge of the block and the plug bottoms out (look at the other plugs for reference)
If you used RTV, let it dry
Close block drain and radiator petcock
Refill coolant
Leak test
95yjman
Re: freeze plug
« Reply #2 on: June 13, 2009, 04:09:51 PM »
thanks bud, I'll give it a try!
