Author Topic: Serpentine belt length?  (Read 4319 times)
« on: June 13, 2009, 04:36:06 PM »
Anyone know off hand what the length of the belt is for a YJ 2.5L w/PS non-A/C?  I seam to have lost my OE belt.  I forget if it's 96" or 98".
« Last Edit: June 13, 2009, 04:36:15 PM by Jeffy »
drunkencityworker
Re: Serpentine belt length?
« Reply #1 on: June 13, 2009, 10:13:48 PM »
I have 95 yj ps no ac and I just replaced mine when I did water pump and put my old as spare in box holder thing. I bought at murrays which just got bought by oriellys.   master pro k060710    6k710    it says 13/16" x 71 1/2" OC  20mm x 1816mm OC  another small number on back under the k060710 is 17790022
bar code number like this
0    29769   19937   4 .
sorry if overkill just happened to have box near by
drunkencityworker
« Reply #2 on: June 13, 2009, 10:16:42 PM »
oh and I have power str and no ac. and theres 6 raised thingies on the inside. I had to bring mine in cause they had diff counts for them on my year
« Reply #3 on: June 13, 2009, 10:40:00 PM »
Thanks for looking it up.
Now that I think about it some more, I think I need the length of a YJ with PS and A/C.
I found this, it looks right.
Years    Veh    Description     Part Number
83/86    SJ    4.2L (258) Serpentine Belt, 81.7" long, 6 ribs w/o PS, w/ 56/66 amp    4060817
83/86    SJ    4.2L (258) Serpentine Belt, 88.2" long, 6 ribs w/ PS, w/ 78 amp    4060882
87/90    XJ    2.5L Serpentine Belt, 73.5 long, 6 ribs w/o AC    53002900
84/90    XJ    2.5L Serpentine Belt, 81.7 long, 6 ribs w/ AC    53001120
91/95    XJ    2.5L Serpentine Belt, 96.7 long, 6 ribs w/ AC, w/ PS LHD    53007539
91/93    XJ    2.5L Serpentine Belt, 71.5 long, 6 ribs w/o AC w/ PS    53007595
91/93    XJ    2.5L Serpentine Belt, 69.0" long, 6 ribs w/o AC w/o PS    53010010
94/95    XJ    2.5L Serpentine Belt, 71.0" long, 6 ribs w/o AC, w/ PS    53031118
96/00    XJ    2.5L Serpentine Belt, 91.0" long, 6 ribs w/ AC, w/ PS LHD    53011035
96/00    XJ    2.5L Serpentine Belt, 79.0" long, 6 ribs w/o AC    53010257
97/00    XJ    2.5L Serpentine Belt, 2415mm long, 6 ribs w/ AC RHD    53012002
96/00    XJ    2.5L Serpentine Belt, 1980mm long, 6 ribs w/o AC RHD    53010311
95/97    XJ    2.5 Diesel Serpentine Belt, 2185mm long, 8 ribs w/o AC    4796033
98/01    XJ    2.5 Diesel Serpentine Belt, 2195mm long, 8 ribs    4883445AA
87/90    XJ    4.0L Serpentine Belt, 102.5 long, 6 ribs    53002899
91/93    XJ    4.0L Serpentine Belt, 97.5 long, 6 ribs LHD    53006870
91/95    XJ    4.0L Serpentine Belt, 2500mm long, 6 ribs RHD    53010279
94/95    XJ    4.0L Serpentine Belt, 97.5 long, 6 ribs LHD    53010269
96/01    XJ    4.0L Serpentine Belt, 97 long, 6 ribs LHD    53010314
96/01    XJ    4.0L Serpentine Belt, 2270mm long, 6 ribs RHD    53010234
93/95    ZJ, ZG    2.5L Diesel Serpentine Belt, 2285mm long, 8 ribs    4797801
96            ZJ, ZG    2.5L Diesel Serpentine Belt, 2275mm long, 8 ribs    4864599
97/98    ZJ, ZG    2.5L Diesel Serpentine Belt, 2195mm long, 8 ribs    4883445AA
93/95    ZJ    4.0L Serpentine Belt, 71.0" long, 6 ribs w/o AC    53031118
93/95    ZJ    4.0L Serpentine Belt, 97.0" long, 6 ribs w/ AC    4612277
96/98    ZJ    4.0L Serpentine Belt, 92.2" long, 6 ribs    53010150
96/98    ZG    4.0L Serpentine Belt, 89.5" long, 6 ribs RHD, w/ 117,136 amp    53054339
93/95    ZJ    5.2L Serpentine Belt, 90.0" long, 7 ribs    53008744
96/98    ZJ    5.2L, 5.9L Serpentine Belt, 89.2" long, 7 ribs    53011097
99-01    WJ    3.1L Diesel Serpentine Belt, 2490mm long, ribs    5015962AA
99-04    WJ    4.0L Serpentine Belt, 88.2" long, 6 ribs    4854033AB
99-04    WJ    4.7L Serpentine Belt, 87.5" long, 6 ribs    53032037AJ
02/04    KJ    2.4L Serpentine Belt, 87.5" long, 6 ribs w/ or w/out AC    53032037AJ
« Last Edit: June 13, 2009, 11:07:48 PM by Jeffy »
drunkencityworker
« Reply #4 on: June 13, 2009, 11:09:37 PM »
are you running on board air or something that would have it rerouted. I was looking at doing homebrew OBA and I know its def way longer the compressor pulley and another idler pulley are added for that.
« Reply #5 on: June 13, 2009, 11:12:43 PM »
I have a York and when I routed the belt, I screwed it up and am using a shorter belt and different pattern.  I think it's around 94".  Problem with this is that it's maxing out my adjustment.  IIRC, for the York, you need to run +6" of the w/AC belt.  So, eventually, I'll get the right belt and reroute it.
